Old 11-12-2010, 08:42 PM
vtwindave vtwindave is offline
98 taurus cd changer
i have a 98 with 6 cd changer in trunk, cd changer will not pop up, all fuses good, even one under hood,. could not find power to cd changer, any suggestions, what to check next?
Old 11-12-2010, 11:24 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 98 taurus cd changer
All power for the CD changer (assuming it's factory) is provided on the red/yellow wire at terminal 9. Power to this wire comes from fuse 17 (20 amp) located in the engine compartment fuse/relay box. It also provides power to the rear control unit (RCU), so if your radio is working, the fuse is likely not the problem. You should be able to trace the red/yellow wire at terminal 14 of the RCU to the changer.
-Rod
Old 11-13-2010, 08:35 PM
thanks, i'll look there next.
Ball joint installlation for 2001 Taurus SEL Doug Tatham Taurus | Taurus Wagon 10 09-28-2020 07:37 AM
2002 Taurus No Start fugiman852001 Taurus | Taurus Wagon 1 09-11-2009 06:20 AM
2000 Taurus Fuel Pump wrong Guage Readings DCV Taurus | Taurus Wagon 3 07-04-2009 05:46 PM
Taurus transmission light and problems mikecorki Taurus | Taurus Wagon 4 06-01-2009 06:39 AM
99 Ford Taurus Waterpump Rust Damage mcdyver1 Taurus | Taurus Wagon 2 05-25-2009 07:36 PM
