Old 11-12-2010, 01:06 PM
ktmccrary ktmccrary is offline
98 GTP SC HELP BNAYLOR! Compound Problem, Temp Gauge, More
I inherited a 1998 GTP 3800 Supercharged car with a host of problems. I've fixed most of them, but I have started replacing items that aren't fixing problems.
The temp gauge self-tests from 0 to max to 0 when I turn on the key, but the gauge never moves off 0 when the engine is running. I have an Actron scanner showing it running at normal temp. This model has a 3-pin (dual output sensor) which I replaced. At first I couldn't even get a reading on the scanner with the new sensor, but traced that to a bad connection in the connector. Now it's back where it was at 0 again.
I have multiple problems and believe they may all be related.
I was getting a p0102 MAF sensor error but traced it to fuse 21 in the underhood fuse panel. Replaced it, blew it and replaced it again. It seems to blow if I rev it above 3000 rpm, and then of course the rev limiter won't allow it to rev about 4000 RPM.
The transmission indicator on the instrument cluster only lights up park when it is in park or when it is in 3rd (stil lights up in park) , All other gears have no indicator light, nor are there any lights on the floor console indicating the gear it is in.
The oil level light comes on whenever the shifter is taken out of park, while the ign sw is on with the engine running or not. I replaced the oil level switch, cleaned the connector, to no avail.
Thus far I replaced the oil level switch, the temperature sensor, and even the instrument cluster, and have solved nothing.
I'm down to either having mouse-chewed wiring somewhere or possibly the PCM is bad. I at least avoided buying a $130 MAF sensor when I found the blown fuse, but I haven't found the cause of the blown fuse yet. Any and all help will be greatly appreciated.
Old 11-12-2010, 01:39 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: 98 GTP SC HELP BNAYLOR! Compound Problem, Temp Gauge, More
I would venture to say you may have a bad ignition harness. However this is truly just a guess. We'll wait for a few other opinions
Old 11-12-2010, 03:20 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
I'm not an expert but I agree with grandprixgtx00 but could this also be a bad ground problem? Have you checked them?
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-13-2010, 08:25 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Ignition switch/harness assembly is possible but I'd troubleshoot further to be sure.
Any other abnormal indications like headlights flickering, no cruise control, no fog lights, abs light on, HVAC issues, no turn signals, engine cutting off when using turn signals?
Timeslip 08/12/06
AF Community Guidelines
Old 11-13-2010, 08:39 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
I didn't know the guages self test on any 97-03 GP's. I thought that was just an 04+ thing. At least I know my temp guage wont start at 0, self test to max, and return to 0 when I start my car.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-13-2010, 09:53 PM
BNaylor's Avatar
Yup actual IP gauge self-test is an '04 and up (final generation) thang.
I think what he meant is at ignition ON the gauge should at least go to what the ECT has for engine coolant temperature. In his case its dead or abnormal.
Timeslip 08/12/06
Old 12-01-2010, 03:41 PM
Sorry, slow to get back. Had to rebuild a freakin Saturn Engine. I actually did mean "self-test". When you turn the switch to the on position the temp gauge needle moves to max, then back to min where it remains even when the engine reaches operating temperature.
I have found some corrsion on both a pos and neg battery wire where it looks like it got into a pulley once upon a time. I need to investigate this further before pursuing other matters. I'll try to get back to you with results. Thanks. BTW this is a HUD model.
Old 12-02-2010, 09:34 AM
tblake's Avatar
In God We Trust
pretty sure its not supposed to self test. i'd have to say you have a circuit problem causing it to max out when you turn the ignition on.
Old 12-02-2010, 07:37 PM
1998 CVPI serious issue right now, need real help b4 i get raked for more $$$ Towboss1971 Crown Victoria 1 06-20-2010 11:39 AM
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
temp gauge and more...please help martini25 Cavalier 1 11-27-2007 01:41 PM
Help with the outside Temp gauge reading clark35 Town Car 3 08-02-2007 07:19 PM
99 Cavalier needs help (shucking action & temp. gauge stuck on cold) cass_17_7 Cavalier Problem Diagnosis 6 01-03-2006 02:10 PM
Tags
gauge , level , oil , prnd321 , temp
