Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-11-2010, 10:28 PM
JephyLube JephyLube is offline
Just picked up my first Rodeo, No Reverse?
Hi i have been reading around and found out basically these transmissions suck.. I just recently bought a 1996 Isuzu Rodeo 2wd version and everything works great except there is no reverse? i work at jiffylube so at work i flushed my transmission out and changed the filter and also changed the external inline trans filter, still no reverse? could it be a bad switch on the tranny or? i have no check engine light and no check trans light, when i put it in reverse the rpms go to 2k all by itself then if i put it in neutral or park it goes back down to 1krpms?? any help would be great thanks
Old 11-12-2010, 12:35 AM
Cat Fuzz Cat Fuzz is offline
Re: Just picked up my first Rodeo, No Reverse?
I'm no trans expert but from what I understand, if you have all forward gears but no reverse, it can't be clutch packs. I would start by dropping the pan and inspecting the valve body. I have a nice detailed .pdf for the 4L30E I'll send you. Just pm me your email.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 11-12-2010, 12:49 AM
Alright ill check that my email is [email protected] thanks
Old 11-15-2010, 07:29 PM
Well i now have new problems, its having trouble going into 3rd gear it feels like if you were to drive a stick and shift to 3rd without using the clutch, and the check trans light flashes after that, the only way i can drive around now is to use winter mode and start in 3rd which is eating the trans up im sure, so im guessing the transmission is toast?
Anyone have a DIY or write up on how to change out the transmission on the 2wd vesrion? im very mechanically inclined so im sure it wont be a problem but there might be some important things i need to do to change it out.
Any help would be great thanks..
I just picked up an Integra Center Console... Skeme1 '88 - '91 Civic | CRX | Wagon | Shuttlee 7 12-22-2002 06:54 AM
Just picked up a 93 Z24...sweet TonyA Cavalier 1 09-19-2002 01:02 AM
i just picked up a PT sdadlani Car Modeling 3 07-03-2002 03:39 AM
Woo hoo, I just picked up my free... kris COMPLETELY off-topic 9 01-09-2002 02:38 AM
