2005 Saturn VUE engine light won't go off
I've been having this problem since April; at first my engine light would come on, and then go back off. Now, it's on to stay.
Normally I would worry about this kind of thing--an engine light exists to tell you when there is a problem, after all. However, each and every time I have the codes pulled--there aren't any. No codes whatsoever. Not even anything to indicate a gas cap problem (which I thought could be the case since the original cap seemed to be bad, so I bought a new one to no avail). The truck itself runs just fine, there is no indication of a malfunctioning anything, anywhere. Just that !#@$ light. Has anyone had any experience with this? Or have any advice about what to do about it? |
Re: 2005 Saturn VUE engine light won't go off
Just monitor, and look for other symptoms.
Advice? Yes, two thoughts.
Have the PCM and I/P checked. Each is a device on the serial bus (along with several other modules and devices) and the lack of communication between them can cause the I/P to light the "Service Engine" light even though there is nothing wrong with the powertrain. The dealer service department should know that. Second, stop thinking of the Vue as a truck. It is a untilzed body (no frame) FWD vehicle, essentially a tall station wagon or "crossover" vehicle. Think twice before towing or hauling heavy loads with it, as you would a true truck. Imagining it as a truck and treating it as such will likely reveal its shortcomings in an expensive way. It's just a taller passenger car with more interior space.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
... thanks for the other advice, though. I'll see if they can find anything. |
engine light or maintaince light? |
