Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-11-2010, 05:39 PM
dimocamaro95 dimocamaro95 is offline
95 camaro LT1 runs good cold, when hot has issues
When the car is cold it runs great. However when you run it for about 30 minutes and shut it off, it won't run properly. The car won't accelerate like its supposede to, sometimes not at all, the exhaust backfires, but it idels how its supposed to. We have changed the ignition module, the spark plug wires, the O2 sensor and coil. We have also elevated the fuel lines off the valve covers and removed the air cover and replaced with something that doesnt cover the top of the motor. Any suggestions????
Old 11-11-2010, 06:36 PM
Scrapper Scrapper is offline
AF Premium User
Re: 95 camaro LT1 runs good cold, when hot has issues
sounds like you may have cracked a plug puting them in or cat might be clogging up. also look for vaccumm leaks and also may be out of time.
Old 11-11-2010, 06:40 PM
AF Premium User
did you buy the parts new you replaced? also check see if spark is yellow or blue yellow no good blue spark good.
Old 11-12-2010, 07:54 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Definately sounds like it could be ignition related. With that said, don't cheap out, get ACdelco replacements, it's worth the extra couple of bucks.
I'd also recomment changing out the PCV valve (should be done with every "tune up")
Old 11-12-2010, 12:29 PM
thanks for replys, not ingnition problem, car starts fine when cold or hot, yes all i use is ac delco parts, learned that long time ago with gm products, plugs have been check along with spark,(blue), no cat on car its been removed, timing is direct drive on this LT1.
Old 11-12-2010, 01:10 PM
wrightz28's Avatar
hmmmmm, plot thickens.
Your symptoms normally lead to an faulty ignition component.
Have you checked the fuel pressure out?
Old 11-12-2010, 04:09 PM
dont think fuel is issue, starts great. even when hot still starts and idles normal,, thinking bout coolant temp sensor being bad, coolant temp idiot lite comes on along with check engine, can run car at cold start no prob, run it 30/45 minute, shut off and try to drive after 30 minute cool down, wont accell past this point, could distrb box be issue after at norm running temp(direct drive timing)
Runs good cold, stalls when hot hb_1234a Villager 8 06-26-2013 10:16 AM
2000 3.2TL runs fine cold, not hot dhspring CL | Inspire | Saber | TL 1 07-31-2010 10:38 PM
99 GMC Jimmy Heat goes Hot Cold hot cold snowlover4u2005 Problem Diagnosis 1 03-19-2008 02:15 PM
89 camero runs good cold then dies after getting hot shelbberz Camaro Discussions 8 06-12-2006 10:05 AM
93 Rodeo runs good cold stalls when warm.. toads98wdc Rodeo | Passport | MU 2 04-21-2005 04:49 PM
Tags
1995 , camaro , lt1
