Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-10-2010, 10:39 PM
87_9C1_89 87_9C1_89 is offline
Adding cruise control?
Hi All --
I have two caprices -- an 87 and an 89, both 9C1s. I'm wondering how hard it would be to add cruise control to one or both. (one is carbureted, the other is TBI -- not sure if that makes a difference)
Neither car had CC as a factory option, but curious of the cars have the wiring harness anyway. If so, what are the steps and parts one needs to add? (presumably the turn signal lever and the CC module itself -- anything else?)
If they don't have the necessary wiring, how much of a chore would it be to add it?
thanks.
Old 11-11-2010, 08:37 PM
Blue Bowtie's Avatar
Registered Offender
Re: Adding cruise control?
Factory cruise control units tapped the VSS signal from the VSS buffer box and used that for a vehicle speed reference. The factory installations required an additional brake pedal switch to break the holding circuit for the cruise when the brake was applied. The 1987 model also used a ported vacuum valve on the brake pedal as a redundant safety device to release the vacuum in the cruise servo when the brake pedal was depressed.
Aftermarket units will have everything you would need for a successful installation. Retrofitting an OEM setup will be quite a chore, and the wiring will not likely be present in the harness.
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 10:41 AM
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 10:59 AM
adding cruise control 2000 - Z3, help quinn408 Technical 1 12-14-2005 02:25 PM
adding cruise control, help quinn408 Z3 1 07-15-2005 08:56 AM
adding cruise control fishing1000 Caravan | Voyager 2 04-01-2005 02:02 PM
