Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 11-10-2010, 05:16 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Aveo keyless remote battery? RK700NR
Anyone know the battery type off hand that can verify what type it is?
Old 11-11-2010, 08:58 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Aveo keyless remote battery? RK700NR
1. Remove the screw from the back of the cover and open the cover of the transmitter.
2. Pull the transmitter out of the cover and carefully detatch the sticker from the unit.
3. Remove the battery and replace it with the new one. Make sure the positive side of the battery faces up. Use one three-volt, CR1620 or the equivalent.
4. Attatch the sticker and put the transmitter unit in the cover.
5. Put the two halves back together and replace the screw. Make sure the cover is on tightly, so water will not get in.
6. Test the transmitter operation.
Old 11-22-2010, 11:45 PM
mike_hussey mike_hussey is offline
I think the battery type is 364 and u can use that batteries
2000 Pontiac Bonneville Keyless Remote Battery Replacement Programming Help pistons19 Bonneville 1 07-25-2009 07:13 PM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
FS 2001 Acura CL Keyless/FOB Remote TMO Classifieds 1 05-24-2009 05:15 PM
Keyless Remote Battery stobubba Grand AM 0 08-25-2005 02:42 PM
keyless remote batteries Aleromommy10 Alero 2 02-11-2004 10:30 PM
