Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 11-10-2010, 12:21 PM
oak2001raid oak2001raid is offline
2000 stratus egr problems????
My daughter has a 2000 dodge stratus. over 100k miles. Today it started stalling on her. When she would back up or go from reverse to forward. I haven't road tested it yet to see how it runs at highway speeds.
I put it on a code reader and the only code I am getting is P0401(EGR flow insufficient).. Would this cause the stalling problems? Or should I be checking something else.. Thanks for any help
Old 11-10-2010, 12:50 PM
danielsatur danielsatur is offline
Re: 2000 stratus egr problems????
The EGR gas passages are probably plugged, clean EGR valve + passages in the Intake.
Old 11-10-2010, 05:42 PM
would that cause the stalling problems?
Old 11-10-2010, 09:22 PM
If the EGR is stuck open, or a bad gasket would cause hard start, stall, rough idle, and poor acceleration.
A blocked, stuck closed, or blocked EGR passages will be insufficient flow, and poor emissions.
Old 11-10-2010, 09:25 PM
jpb53 jpb53 is offline
An EGR valve that is open at idle can cause an engine to stall. The code is for insufficient flow. The valve is not supposed to be open at idle. If it is open at idle and you drive the vehicle and when the conditions are right the computer will ground the vacuum solenoid to activate the valve. Since the valve is already open when the computer is commanding the valve to open there is no change seen from the input of the MAP sensor. So yes you can have this code and a car that stalls at idle.
2000 Mercury EGR PROBLEM AutomotiveServWork Cougar 0 06-28-2010 09:07 PM
2000 300m EGR problem s.walters 300M 3 09-17-2008 10:08 AM
2000 Stratus Tranny Problems chadsta Stratus 10 05-20-2007 12:40 PM
2000 Stratus Ignition Problem Bruticus Stratus 1 12-31-2004 03:03 PM
2000 F150 EGR Problem? FastCat F Series 0 11-07-2003 07:40 AM
