Old 11-09-2010, 04:59 PM
jylhami jylhami is offline
Yamaha Trial TY125 1:8
Hello,
Next project is a Heller kit: YAMAHA TY125 Trial bike at 1:8 scale.
The real thing:
Engine is glued together, wheels cut off and the hubs are drilled for insect pins.
Will make a jig to drill and assemble the wheel with the spokes.
Engine will be bolted to the frame to be able to build the complete engine and detail it out of the frame.
First try on rear sprocket went wrong, too much rpm and too little feedrate on my DIY CNC router:
The handlebar will be attached with 0.9mm screws:
Update will follow as there is some progress
Old 11-11-2010, 02:29 PM
Re: Yamaha Trial TY125 1:8
Some progress, made jig for the wheel assembly and routed new sprocket:
Old 11-13-2010, 02:29 PM
Some little progress again.
Bent the handlebar from 2,5mm welding material:
Also testfitting the spokes and a nibble on the jig:
Next i will need to paint the hubs and the rims and start to actuallu put them together.
Old 11-13-2010, 03:55 PM
sportracer02's Avatar
Looks cool so far, clean working style, I like that
Micha
Old 11-15-2010, 01:57 AM
protarguy protarguy is offline
Hello jylhami!
Very nice work!
What do you use for the spokes?
Uli
Old 11-15-2010, 04:30 AM
Hi, Uli.
Thanks !
The spokes are 0,4mm stainless steel insect pins, that took long time to find a right model. Finally find them literally from the other side of the globe: Ento supplies, Australia. http://www.entosupplies.com.au/
Old 11-15-2010, 08:46 PM
cinqster's Avatar
cinqster cinqster is offline
Very nice work! I managed to get variously sized insect pins from a company in the UK, but have long since lost their address!
Out of interest, are you going to use the engineers pens for the spoke nipples? That will be expensive!
Minimeca make very small diameter stainless steel tubes - I think they're Switzerland based, if that helps? Some of their tubes are around 10mm long, so you can cut two, or three, 1/6th spoke ends from each one.
Good luck, it's looking good already!
Old 11-16-2010, 12:12 AM
I just got a link from fellow modeller in Finland. A UK based company to supply insect pins: http://www.watdon.co.uk/the-naturali...alog/Pins.html
Old 11-16-2010, 02:05 AM
Thanks for the link for the insect pins.
I was also searching for the metal head type.
In Germany you only get the type with the nylon head.
Here is another source for steel tubes form Hobby Design
in various sizes:
http://www.plasticmodelkits.net/cata...sort=3d&page=3
Uli
Old 11-16-2010, 02:39 AM
quadzero's Avatar
quadzero quadzero is offline
I love the subject matter and your work is amazing. I look forward to more progress on this great project. Can't wait to see how the rims turn out.
Old 11-16-2010, 04:22 AM
Got the front fork shafts from old screwdriver:
Also got the front rim and hub painted with Gunze's Mr Metal aluminum and started the spoke work. Pictures coming later...
Old 11-16-2010, 04:27 AM
No the nibbes will be cut from injection needles (i have a friend who is a nurse, so no issue of spending money )
Old 11-17-2010, 05:30 AM
DOCQUINO DOCQUINO is offline
Impressed, I like your building and kit chosing a lot. Not common to see this subject, so its more valuable. Im subscribed waiting to see a lot more.
Old 11-17-2010, 12:27 PM
Some progress, got (almost) the front wheel spoked tonight... i just ran out of the injection needles = nibbles
The tyres are not so good, finish is too glossy, already tried to rub it with steel spunge, but still too glossy.
Old 11-17-2010, 03:49 PM
Hello ,
the wheel looks very good, but I guess there are at least two spokes missing.
The tires are always a problem in Heller kits.
I noticed some shrinking and cracking up on some older car models.
Uli
YAMAHA YZR-M1 2006 CAMEL No.46 YongGun Park Completed Projects / Gallery 31 10-07-2012 03:32 AM
Heller 1:8 Citroen Traction Avant 15/6 AmazonSprite Car Modeling 12 07-13-2009 05:49 PM
The 1:8 scale Ferrari F40 Progress Thread SupercarFreak WIP - Street 318 12-15-2005 02:07 PM
how to make 1:8 turbos builder Car Modeling 15 07-22-2005 05:28 PM
1:8 scale F40 brakes SupercarFreak WIP - Street 18 06-29-2003 04:44 AM
