Old 11-08-2010, 06:32 PM
cwilliams1996 cwilliams1996 is offline
2000 alero 02 problem
2000 olds alero 2.4 t code trying to get it to pass inspection a engine was installed earlier on im stuck with it its giving a po 130 code no or little activity i replaced the o2b1s1 whith the scanner hooked up it showes the same voltage as when its pluged in or unpluged it will not go to closed loop and no rich lean transition any body have any ideas
Old 11-17-2010, 08:35 PM
Blue Bowtie's Avatar
Registered Offender
Re: 2000 alero 02 problem
Check the voltage of the sensor right at the sensor instead of reading it through the PCM. I suspect a wiring problem between the two, or a PCM input problem.
2000 Alero 2.4-skips, jerks, dies, poor gas mileage summersdad Alero 8 03-08-2012 09:23 PM
2000 Alero problem???? [email protected] Alero 2 08-06-2009 09:41 PM
2000 alero problems sqhurt Alero 2 10-07-2007 05:48 PM
Alero 2000 2.4l problems, 2000$ in reparations, still problem Adoh Alero 3 02-11-2007 11:14 AM
2000 Alero problems, possible sensors???? twright1 Alero 1 12-28-2004 09:57 AM
