Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 11-08-2010, 01:33 PM
KelevraGreywolfe88 KelevraGreywolfe88 is offline
Exclamation Cant find the ground on my 91 Toyota pick up
I feel like an idiot but i cant find the dang ground on this truck, can some one help me please
Old 11-08-2010, 10:20 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Cant find the ground on my 91 Toyota pick up
The ground should be under the tires.
There should be 3 ground wires
from batt neg to inner fender
from inner fender to frame
from firewall to engine
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 11-13-2010, 12:15 PM
Ok do you happen to know which of thoughs will go to the tail lights cause my dad said that that is what is causing my tail lights not to work. it dose this crazy ass thing were the left tail light will be lit but when i step on the breaks it will shut off and the right break light will come on
Old 11-13-2010, 12:48 PM
mcmalloy mcmalloy is offline
if someone has wired in a trail harness you will probly have to pull it all apart and start from scratch
Old 11-13-2010, 12:56 PM
But theres not one
Old 11-13-2010, 01:09 PM
pull the tail lights out, check the pig tails and ground wire for the taillight harness
Old 11-14-2010, 09:03 PM
fourwd1's Avatar
AF -Advisor
Yes, pull out the tail lights, there should be a ground for each side.
89 4Runner - stock
Old 12-30-2010, 08:09 PM
cris8746 cris8746 is offline
Cris
I had trouble with trailer lights and could not find a ground wire from frame to bed so I put one on and the problems are fixed.
cant find the problem crazyman20463 F Series 1 04-01-2005 12:25 PM
Rant about how i cant find the perfect car for me to tune... (swearing, cursing, etc) ricergribbs Stress Release 23 04-16-2004 11:44 PM
Cant find the Oil press. sensor! SteveJH Ranger | Courier 3 03-19-2004 05:57 AM
Cant find the "main fuel relay" ajimmbo Prelude 0 09-01-2003 07:21 PM
Cant find the Fujimi web site chrismcgee Car Modeling 7 07-04-2003 09:07 AM
Tags
ground
