Old 11-07-2010, 08:44 PM
ptcfast2 ptcfast2 is offline
Weird Vibration from Rear
Since I've owned my Lumina I've had vibration problems. I've managed to isolate and fix the causes one by one, but I'm stuck on this last puzzle!
I rebuilt the rear drum brakes on my Lumina a few months back (new pads, drums, cylinder, etc...) in an attempt to cure a vibration that was emanating from the rear end when I applied the brakes and decelerated the car. This vibration occurs from any speed over 50MPH when the brakes are applied. The vibration dissipates once you hit the 40MPH mark and the brake pedal feels normal. I know that the rear wheels are causing this as I've confirmed with the parking brake at high speeds.
I'm thinking that the bearings might just be worn out as they've got 226,000 miles on them. I've read a few places that worn/pitted bearings can cause vibrations at certain speeds & when a certain amount of force is applied in a general direction on the bearing due to wear.
Anyone have ideas/care to confirm my suspicions?
Old 11-07-2010, 09:44 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Weird Vibration from Rear
Bearings like this usually rumble or moan when they have anything wrong. I can't say it's impossible, but doesn't sound likely.
I'd be trying to make sure I wasn't dealing with a chunked or missing trailing arm bushing or something like that...I guess you've already eliminated the tires as a cause? A broken tread belt will do stuff like that sometimes...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-07-2010, 09:53 PM
Tires are pretty new (got them around this time last year). They aren't the best in the world (Goodyear touring tires) but they've done the job so far. Honestly, the only reason I've ruled them out at this point is because the vibration is only during decel and not acel (I would think the vibration would occur both ways). The trailing arms & bushings are brand new as well as the struts in the rear and front.
The vibration itself is more intense the harder I slow down. It varies with the amount of pressure put on the brake, and in turn how fast the car decelerates. Faster = More intense until I reach that magical 40MPH point. Maybe it is a brake problem? I mean it could be a bad drum that's just a bit off...(old ones were bad, I might have gotten bad ones as replacements as well...it happens!).
Old 11-07-2010, 10:05 PM
See, on a FWD car, the only time the rear tires are under any real tread belt stress is under braking, other than that they just follow.
Usually on the rear, the only time you'll feel a belt separation is under braking...
I'd rotate them and see what it feels like after, just to rule it out. Easy and free...
...empty gun rack.
Old 11-07-2010, 10:07 PM
Good idea. I'll do that tomorrow when I'm changing the oil and get back with the results.
Old 11-07-2010, 10:19 PM
It's possible it could have a bent stub or flange back there too...watch the gap between drum and backing plate for any weird runout while you spin the wheels...
...empty gun rack.
Old 11-08-2010, 08:06 AM
maxwedge maxwedge is offline
A990 racer
"Bell mouthed" drums could do that also.
Old 11-14-2010, 01:33 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Did you have the drums turned before installing them on the car? What method did you use to bleed the aair out of the system?
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Weird Noise From Rear Divorce Court Dan Lumina 2 11-07-2006 07:51 PM
vibration from rear mrd330 S-10 13 04-07-2005 11:30 AM
Weird Sound from rear of car avpart3 Tires and Wheels 6 06-22-2004 03:41 PM
97 Astro Vibration from Rear ecal533 M Bodies 0 06-06-2004 06:33 PM
