Old 11-07-2010, 01:38 PM
Applianguy Applianguy is offline
timing marks off???????
I'm trying to reinstall a distrib and when the #1 piston is at the compression stroke the timing marks on the crank pulley are way off. What now??????? New hormonic??????
Mike
Old 11-07-2010, 01:56 PM
danielsatur danielsatur is offline
Re: timing marks off???????
Are you sure it's on the compression stroke, use a compression guage?
4-strokes per cylinder!
Old 11-07-2010, 02:11 PM
Yep......used compression guage, as soon as pressure showed pulled guage and topped the piston with a straw. At top the timing marks were bottom of crank pully????????
Old 11-07-2010, 02:40 PM
Like 180 degrees off!
Old 11-07-2010, 04:37 PM
No........more like 3 inches from mark on crank to mark in timing cover. Can the harmonic have slipped??????? Lining up marks an piston is half way down.
Mike
Old 11-07-2010, 04:38 PM
old_master's Avatar
Advisor/Moderator
Compression tester will show 2 pulses for each crankshaft rotation. A weak one on the exhaust stroke, and a strong one on the compression stroke. Watch it closely while it's cranking and you'll see the difference.
Follow these and it will be right on. If the distributor is off one or more teeth in either direction, P1345 will be set. If no P1345, you've got it right. When you've got it installed, check camshaft retard with a capable scan tool. Should be zero, plus or minus 2 degrees.
You have to know how it works,
to figure out why it doesn't.
Old 11-07-2010, 05:30 PM
When I line both marks like that #1 piston is halfway down cylinder????
WTF?????????????
Old 11-07-2010, 06:00 PM
old_master's Avatar
Advisor/Moderator
Did this thing run before you took the distributor out?
Old 11-07-2010, 06:20 PM
Yes it ran great except for a lower intake waterleak. Person helping yanked dist out without marking it.....last time I leave to take a pee!
Mike
Old 11-07-2010, 11:33 PM
viggy58 viggy58 is offline
when i took mine out for the intake gasket job, i had to get it set at TDC, then use a long screwdriver, to make the input for the oil pump line up, otherwise it was off.
Make sure you get to TDC, then put the distributor in. look at the second image that old master posted. if the rotor is not in the right spot, you will have to manually turn the oil pump until it rotor is in the right spot. kinda tough. you'll need a flat blade at least 8 inches long i think, then you just have to feel it out. take the dist out, and stick the screw driver down the dist shaft. if you can get some light in there, you'll see what you need to aim for.
This usually happens if the car is moved with the dist out. in my case, my old ass clutch slipped, and the blazer rolled about 3-4 feet.
if this sounds like more than you want to mess with, a local shop will usually get it all setup and in-time for about $60-$100. if you can get it close enough to run, the comp will compensate enough to drive it a couple miles to a shop, if necessary. It was actually a local mechanic who told me what to do to fix mine.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 11-07-2010, 11:59 PM
Been there got oil shaft no problem. Problem is that with the piston at the compression stroke and topped up, the timing marks on the crank are way off. I'm thinking harmonic balancer slipped. I did find the bolt loose but the keyway is ok. I'm NOT guessing on timing this thing..again
Thanks Mike
Old 11-08-2010, 05:40 AM
old_master's Avatar
Advisor/Moderator
Just making sure here.... #1 plug is on the driver side. If the marks are off and the woodruff key is ok, the dampener must have slipped. If that's the case, get #1 piston on TDC and install the distributor. If it won't start, the distributor is 180 degrees out of phase... pull it and rotate the shaft 180 and reinstall.
Old 11-08-2010, 09:43 AM
I know you have to check for a dummy but yes I know were #1 cly is. I looked at my 96 s10 4.3 today and the timing marks are differant in comparison with the woodruff key location. So either it a differant engine or the damper slipped or wrond harmonic. I'll have a new one on there by tonight. Is anyway to tell if its a "W" engine? And can any "w" engine replace it? This is suppose to be a 14,000 mile motor but has 200,000 in ugliness inside.
Thanks...mike
Old 11-08-2010, 03:54 PM
old_master's Avatar
Advisor/Moderator
95 and older W engines are CMFI, large plenum on top of intake. 96 and newer is CSFI and has a low profile black plastic plenum. Better check with a boneyard on the interchange for the dampener. I don't believe they're interchangable. 95 and older did not use a crankshaft position sensor, 96 and newer does. Somewhere around 2001 they became an X motor. The only difference is the X has injectors at the intake ports instead of centrally located. It's a great upgrade for 96 and newer W engines. Check your old dampener, see if the rubber looks like it shifted, if not, just bring it up to TDC and use the dampener you have.
Old 11-08-2010, 06:15 PM
There isNo crank sensor and it has a large metal upper intake. Can I upgrade to CSFI if I change COmputer and will a 96 computer plugin???????
Thanks again
mike
4.3 timing mark coldinmichigan M Bodies 1 02-01-2010 01:02 PM
2000 dodeg stratus, 2.4. lost the timing marks fishpaste Stratus 1 07-30-2009 11:18 PM
timing marks/balancer Top Dead Center thehustler211 Problem Diagnosis 1 03-28-2009 11:31 PM
2.0 z-tech timing belt , no timing marks ocrank pulley 67VETT Contour 2 03-19-2008 09:00 PM
Timing marks off, advanced to the max jondaphenom114 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 07-31-2005 10:55 PM
