1988 Suburban Intermittent Starting
I recently purchased a 1988 V20 Manual suburban. It is an awesome rig and just reached 100k on a recent 3,000 mile fishing trip. It drove without a problem. Recently it has had power failure at random times and will make a clicking sound when attempting to start (like it isn't throwing enough volts to crank). I removed the starter and had it tested and it is fine. I put the starter back on and it fired right up. Now it is giving me the click again. It has 2 batteries and I am not sure what purpose the 2nd serves. The bolt to the + terminal on the primary battery does not tighten completely and I think it may be the source of my troubles. The battery is new and the cables seem fine. Any ideas?
Re: 1988 Suburban Intermittent Starting
load test both batteries at the battery supplier. operate with one battery . all battery connections must be clean and secure. disable the ignition , then using a meter have the engine cranking and look for voltage drops starting at the battery leads... remember positive and negative/ground wires must both be good ............ |
Thanks for the help! Another thing worth mentioning is that I do have power but cannot get power to the radio or dome light even though I replaced the fuse. The vehicle will start fine if I hook it up to jumper cables but I cannot get the radio and dome light going. I want to think it is the battery but I m a bit confused about the other electrical issue. I will run the tests you recommended tomorrow for a good start to solving the problem.
