Old 11-05-2010, 08:41 AM
drunken monkey's Avatar
Razor Sharp Twit
Revell Ferrari 308 GTB 1:24
...and another one gets dusted off.
Original WIP here.
After much messing around with the body, I finally gave up and called it done when it was still full of problems.
You can just about see it but sometime between me fixing on the 288GTO bonnet and me finishing up the painting, it had "curled" up slightly and the nose now sits at a 1 degree angle from the horizontal.
Follow the black body line and you'll see it.
I've tried my best to hide it by careful photography but every now and then, it rears its head in some shots.
Also, once I re-trimmed the window frames, the squished look has come back a bit which means I hadn't taken off enough material.
Could be though, that I need to paint the lower rocker panels black as they did on the real cars.
Two shots to show the effect of my using a polariser.
Position 1.
Position 2.
Not that brilliant a demonstration but you can that the adjusted position meant I had some reflection on the bonnet of the car.
Again.
Position 1.
Position 2.
For those that can, try it.
I really liked this kit.
Some of that is probably down to it being one of the first OOP kits that I tracked down.
Part of it is probably down to it having an engine.
With that said, I know that there are some areas of the kit that are pretty shoddy.
Suspension details are mediocre.
No brakes.
Molded solid grills/gills/vents.
Bad clear parts - especially the rear lights that are the same smoked plastic as the window parts which makes painting them the correct colour impossible.
Incorrect rear glass detail.
But the attempted full detail kinda makes up for it, especially when you can scavange from the Hasegawa 328 kit for more accurate parts.
Coming.
Going.
With "Big Little Brother".
A fun pair.
Set of three showing effect of Polariser positions again.
A pair to try and show you the size difference between the two.
In case I never mentioned it elsewhere, the 288GTO was painted Tamiya TS-08 (Italian Red) over white primer and the 308GTB was Humbrol (New Formula) Ferrari Red.
You can see here (and in the others) that the Humbrol colour has that orange tinge to it that better represents the older Rosso Corsa of the 70s compared to TS-08.
AF's Guidelines
Read them.
Old 11-05-2010, 10:17 AM
360spider's Avatar
Re: Revell Ferrari 308 GTB 1:24
Nice pair! Revell kit is quite horrible, I've built it long time ago. It is also smaller than 1/24, I'd say its smaller than 1/25 even, and looks weird compared with other kits. You did a wonderful job on it though, paint looks superb!
ItalianHorses.net
Old 11-06-2010, 08:45 AM
dmacb's Avatar
dmacb dmacb is offline
You did a good job. Just keep it away from 1/24 builds.
Old 11-06-2010, 12:57 PM
Mojo_stevo's Avatar
Mojo_stevo Mojo_stevo is offline
Great job you did here. I love old Ferrari's.
Old 11-06-2010, 03:18 PM
Razor Sharp Twit
are you sure?
I've compared it and its parts with the Hasegawa 328 and they pretty much match like for like.
A (poor) top down shot of them side by side.
The 328 isn't on its wheels so it'll look a little smaller but even here, you can see the close match, espcially in the wheelbase.
AF's Guidelines
Read them.
Old 11-06-2010, 04:27 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Looks good. I was hopeing to see this one finished. I've been working on old projects too, i just haven't had your results yet.
SCCA 7, The lost Z
Revell / Monogram Ferrari 308 GTB AmazonSprite WIP - Street 5 10-31-2008 05:52 PM
Ferrari 308 GTB Revell ferrari2k Completed Projects / Gallery 2 07-13-2008 12:47 PM
WIP Revell Ferrari 308 GTB drunken monkey WIP - Street 10 04-15-2008 10:54 PM
Modified Ferrari 308 GTB --- PICS --- juki86 Car Modeling 4 03-19-2003 09:16 AM
Monogram Ferrari 308 GTB ZoomZoomMX-5 WIP - Street 6 09-13-2002 04:47 PM
