Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 11-04-2010, 04:57 AM
alexmotorman alexmotorman is offline
Question programing PCM
Linclon Town Car Excecutive 2004 which diagnostic tester do I require to re-program PCM and what process.
Old 11-04-2010, 05:47 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: programing PCM
What kind of re-programming do you want to do? To install a tune to change shift points, spark timing, cooling fan temperatures, etc., I suggest the SCT X3 flash device with a custom-made tune from Blue Oval Chips. Lonnie at BOC makes the best tunes for our cars.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Got P0601 Internal Control Module Memory Checksum Error replace PCM or RE-Programm? gujju Caravan | Voyager 1 09-30-2010 11:01 PM
Crankshaft Sensor? PCM? Camshaft Sensor? elninoeso Ram Van 14 06-10-2009 12:19 AM
Programming PCM truc0011 Montana/Montana SV6 0 05-26-2009 09:51 AM
Re-programmed PCM jcurry05 Grand Prix 3 12-19-2006 05:03 PM
Programming PCM/ECM Vettepartz C/K 4 08-05-2004 07:35 PM
