Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 12-18-2006, 11:25 PM   #1
jcurry05
Re-programmed PCM
Does anybody know a good place to by re-programmed PCMs for a 2000 GP SE with a 3800? I'v only found one place and I would like to have options. Also would anyone recomend using Coil Spring Adjusters to lower the suspension of a car, I ask because it seems a little to easy of a solution not to have drawbacks. Thanks
jcurry05 is offline   Reply With Quote
Old 12-19-2006, 12:58 AM   #2
MVGTP86
Re: Re-programmed PCM
check out zzperformance.com. If you want a DHP powertunned pcm go to 3800performance.com. ZZp can custom tune your pcm the way you want it for little or no extra charge, and its only 79.99 for a reprogrammed pam from zzp. If you need more info just ask.
2003 GTP - Brand New L67 crate engine, K&N FWI, Ported TB, 3.4 s/c pulley, Walbro 340 fuel pump, 180* T-stat, 1.9's, PEM'S, ZZP 3" Down Pipe, ZZP 1.0 PCM, gutted cat, u/bend - resonator delete, magnaflow mufflers and tips.
MVGTP86 is offline   Reply With Quote
Old 12-19-2006, 05:37 PM   #3
jcurry05
Can you even get a reprogrammed PCM for an SE? All the ones I have seen are for the gt and GTP.
Old 12-19-2006, 06:03 PM   #4
MVGTP86
Im pretty sure As long as it's a 3.8L and not a 3.4 or 3.1 you can get one reprogrammed or find someone around your area w/ a DHP powertuner do reprogram it for you. To make sure e-mail zzp and see if they can custom tune your pcm if its an SE w/ a 3.8L.
