Old 11-03-2010, 03:02 PM
duke_winchester duke_winchester is offline
97 Grand Prix GTP shutting off/tach problems
I have a 1997 Grand Prix GTP, and for a few months now, at random, I will notice that my car seems to do what feels like a misfire/jerking action and then my tach completely dies, but the car still drives. Today, the car was very hard to start. I needed to turn it over for quite some time, but I finally got it started. On the way into school, it died twice on me, both times when slowing down to stop at lights. After each, it was hard starting again. This afternoon, it started fine without trouble, but when I pulled into my driveway, the car shut off again and was very hard to start again. Any ideas? Does this sound like the crank position sensor?
Thank you
Old 11-03-2010, 07:05 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: 97 Grand Prix GTP shutting off/tach problems
yes sir, sounds like classic symptoms of a bad CPS.
Old 11-03-2010, 07:27 PM
Any suggestions on how to keep tension on the crank pulley in order to remove the bolt and when re-torquing it after installation?
Old 11-04-2010, 12:26 PM
rkvons's Avatar
rkvons rkvons is offline
Go here:
http://www.automotiveforums.com/vbul...d.php?t=652664
Well, this link is no good. Sorry. You have to put a ratchet over the nut and lay it on the forward frame member and then kick it over with the key. This will get it off. Someone else can chime in about putting it back together, but you need to clamp the flywheel.
Old 11-04-2010, 03:27 PM
What about chocking the wheels, then putting the car in drive (not running of course), and turning the nut then? Won't the entire driveline be engaged and thus the pulley shouldn't turn (unless I was superman) when I turn the nut?
Old 11-04-2010, 05:11 PM
OK. Got the crank pulley bolt out. Now I can't pull the pulley off?
Old 11-04-2010, 05:40 PM
Anyone know what thread size the bolt holes are for the harmonic balancer when using a pulley removal tool? M8 seems to be too big
Old 11-04-2010, 08:47 PM
I'm fairly positive it is a 7M. Someone will correct me if I'm wrong
Old 11-04-2010, 08:54 PM
I just ran across an article on replacing the CPS that said the bolts are an unusual thread: 1/4-28 x 3 inch.
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
1998 pontiac grand prix gtp 4T65E HD tranny problem and dtc's!!! daytonapacecarguy Grand Prix 5 05-09-2010 12:56 AM
97 Grand Prix GTP metal or grinding front sound when let off gas lower speeds? milladog Grand Prix 2 06-23-2007 09:55 PM
97 Grand Prix GTP cuts off/shopped 4x sailorscent Grand Prix 1 08-11-2005 03:21 PM
