Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 11-03-2010, 10:04 AM
half-fast half-fast is offline
Air Bag Code 51
I just connected my code reader to the diagnostic port on the left fender well and followed the procedure for clearing all permanent memory codes. The AirBag Code 51 stopped initially, but then resumed. IE- after the reset, the code didn't begin flashing immediately as it had been.... it took a while before it resumed flashing. I presume this meant it was erased, but then re-established when I started the engine. Code 51 supposedly means there is a blown "Internal Thermal Fuse" in the control box behind the glove box.... which I did locate.
I'll also check the grounds on the sensors when I locate them. Haven't began searching yet.
Now to the question...
What is the procedure for changing this fuse?
What type is the fuse?
Readily available or a Ford/Lincoln Dealer only item?
Old 11-03-2010, 05:37 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Air Bag Code 51
Hi there,
I've never done this kind of repair but I here's some input about thermal fuses:
there are different types of thermal fuses some of them look like a resistor and some others look like common cylinder fuse with something inside, the type normally used on cars is the one that looks like a resistor most of the time is silver colored.
To replace it you'll need to either desolder it from the PCB or just swap it like you would do with any other in line fuse, I lean more towards the desoldering type. The type can most of the times be read from the fuse itself once you've taken it apart.
Finally these type of fuses can be bought at any electronics component store (radioshack, etc.)
Hope this information helps...
Regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
1998 Ford Ranger Air Bag Code 27 edlmmx Ranger | Courier 64 08-17-2013 12:13 PM
Air bag code 44, Windstar 96, 3.8l kafkacell Windstar 0 09-07-2010 07:56 AM
1996 Suburban air bag system ground 1993Suburban Suburban 1 07-05-2009 08:50 AM
air bag code ? speeding turtle Taurus | Taurus Wagon 5 01-10-2008 12:00 PM
