Old 11-02-2010, 01:22 PM
DennisG_02Silvy DennisG_02Silvy is offline
2004 silverado 4.3 to 5.3 swap help needed please.....
Ok so me n buddy along with a few to help out got his v8 swap done on his '04 silverado. Motor is out of a '02, harness is from an '03, and computer vin is from an '04 5.3 sierra.....
Its getting fuel and motor is spinning. So far the only things that we are seeing issues with is..... No spark and its throwing an p0315 code (Crankshaft position (CKP) system variation values are not stored in the PCM memory)
Any suggestions on where to go from here?
The only swap i've done is mine which is an '02 and someone elses which was an '01, both started on first try after priming system
Old 11-03-2010, 07:02 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
Re: 2004 silverado 4.3 to 5.3 swap help needed please.....
Check your CKP sensor down by the harmonice balancer. It is on the passenger side of the motor. It is just one two wire plug and one 8mm - 10 mm bolt. I would replace that and then go from there. Is the motor ran off a distributor or infividual coil packs?
Old 11-03-2010, 10:12 PM
kahjdh's Avatar
kahjdh kahjdh is offline
coil packs, are you sure that the tone ring on the crank for an 02 is the same as an 04? If it is just alittle off it wont run.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-03-2010, 10:17 PM
kahjdh's Avatar
Looked on car-part and 02 to 03 body change the engines dont interchange, the crank is prob slightly different. You need to find a 99-02 computer.
Current Cars:
Past Cars:
Old 11-03-2010, 11:18 PM
i changed the cam and crank sensor. still nothing motor is spinning and fuel is getting in motor but just no spark.
on coil side (pink wire) i'm getting a constant pwer source when key is forward. nothing else on other two wires
crank sensor side (ligth green) i'm getting a constant power source when key is on. nothing from yellow/black and dark blue wires
i checked on quite a few web searches and supposedly their all the same up to around 07
there was only two different rings
they might say they don't work bc a few of the sensors have different plugs and 03+newer has an elctric TB along with maby have no egr and return style.
i have a motor out of an 05 (i have an 02) the only thing i changed was oil pressure sensor which was a totally different style. o and i put a DBC TB on
Old 11-04-2010, 09:58 PM
I did some looking around and since you swapped a lot of things you may need to do what is called a crank relearn or possibly relearn your computer. You will need a GM Tech 2 for this. Since the computer is newer, it will have to have all the new values programmed and stored in to it. You have individual coil packs and they do not know when or where to fire.
Need Help!! whitelightning07 Silverado 3 05-31-2010 12:53 PM
2005 3.5 engine rev while shift mr.daverino Altima 0 03-21-2010 09:28 PM
2001 5.3 Lt Silverado _Monty_ Silverado 0 02-22-2010 01:56 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
1997 chevy 4 X 4 1500 5.7 Wont Start Need Help! Rebel Racing 3 C/K 3 09-19-2006 03:36 PM
