Old 05-27-2010, 11:07 PM
whitelightning07 whitelightning07 is offline
Need Help!!
I have a 02 silverado 5.3 4l60e with a cold air intake, throttle body spacer, comp cams 228/228 .588/.588 112 lsa and i just bought a jet dynamic spectrum tuner and cannot by any means get my truck to shift or stay running. i do not have any kind of dyno shop anywhere close to me and need help! any advice or links to website to help would be much appreciated.
Old 05-31-2010, 11:50 AM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: Need Help!!
I would call nelson performance and they could send you a reprogrammed pcm with all of the specs you need.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 05-31-2010, 12:48 PM
Elbert Elbert is offline
Re: Need Help!!
is the cam you have (assume you installed it) rated to work with your truck / fuel injection setup? You can spend a whole lot of money on this stuff without much gain in real power. You might consider putting a new stock cam in engine. Just swapping the camshaft will not show significant gains in an otherwise stock engine. Getting something like that to run right is an expensive challenge.
Elbert Clarke
Old 05-31-2010, 12:53 PM
maxwedge maxwedge is offline
A990 racer
Re: Need Help!!
Thats a pretty big cam to get to perform in a truck with stock gearing and convertor, I am sure low and mid range torque has been affected, as well as idle vacuum, are you sure you have .588 lift? How about exhaust, stock? Any check engine lite on?
Tags
5.3 , cammed , probelms , silverado , tuner
