Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 11-01-2010, 11:28 PM
flrydr flrydr is offline
engine noise after oil change
I took my 99 avalon in for an oil change, but when I started the car the next morning the engine sounded like there was something was loose in the front valve cover, but after starting and stopping the engine to check things like oil level the noise sort of went away. I say sort of cause it did it for a couple of seconds for my dad to hear then it ran quiet, could it be the valve train needing adjustments? it has 170,000 miles. your thoughts guys.
Old 11-02-2010, 10:15 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: engine noise after oil change
I would replace the oil and oil filter. It may be that they put the wrong filter on or used the wrong viscosity oil by accident. Just because the correct part number or viscocity is listed on the invoice doesn't mean that's what was installed.
Check the accessory belt(s) and make sure they are all approximately tensioned correctly.
Check the coolant level in the radiator and the tank (cold).
Not likely the valve train.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
knocking after oil change 3.1 moemo Cutlass Series 1 10-20-2010 06:37 PM
engine noise after oil change/sticky lifter maybe,can some one help me 2005chevimpala Impala | Impala SS 33 01-25-2009 05:35 PM
Engine noise after oil pump change jeepdad1 Wrangler 1 03-28-2005 02:40 PM
Engine Light after oil change MidMazar GTI 1 03-06-2005 04:10 PM
Engine ticking after oil change ALinVA Corolla/Matrix/Voltz 4 10-07-2004 09:29 PM
