Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 11-01-2010, 08:09 PM
johnboy8899 johnboy8899 is offline
95' thunderbird not starting
If the car is in park or neutral i get nothing from the starter. Replaced the battery and solenoid still nothing but you can jump the solenoid and it starts right up.Does anyone happen to know where the neutral safety switch is located?
Old 11-02-2010, 07:21 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 95' thunderbird not starting
Welcome to the forum johnboy8899. It is located on the drivers side of the transmission. Try holding the key in the start position while moving the shift lever back and forth slowly between Park and Drive to see if the transmission range sensor (neutral safety switch) is out of adjustment. Be sure you have your foot firmly on the brake pedal! Does your car have an anti-theft system? That could cause your problem also.
The Original 97Bird
Old 11-13-2010, 02:00 PM
It does have Anti-theft and a remote starter.Could either of these keep if from starting?
Old 11-15-2010, 06:54 PM
97Bird's Avatar
yes
The Original 97Bird
Will not start (sort-of randomly) caffeineaholic Caprice 7 08-04-2010 08:13 PM
93 villager no click no crank no start klee2183 Villager 1 02-28-2009 08:04 AM
95' Taurus not starting... what could it be? Taurus3.0 Engineering/ Technical 0 01-12-2007 02:16 PM
95' SC1 not starting hyldalea SC/SL/SW 9 01-22-2006 02:17 PM
95' SC1 not starting hyldalea SC/SL/SW 0 01-20-2006 07:49 PM
