Go Back   Automotive Forums Car Chat > Chevrolet > Uplander
Old 11-01-2010, 05:44 PM
phipps phipps is offline
Service Brake System Msg & Light
We have an 06 Uplander and had been experiencing an intermittent Service Brake System message and light. This is the service brakes not ABS message.
It was needing pads so I thought maybe it was just low brake fluid. I replaced the front pads today and now the light and message are constant. I didn't open anything up. The pedal feels fine.
Any ideas what might be causing it?
Old 11-10-2010, 08:01 PM
spike88 spike88 is offline
Banned
Re: Service Brake System Msg & Light
As first fix, I would bleed the brakes. Sounds like air in brakes or air bubble within ABS unit. If that doesn't work, get a reader and "read its code". Its code will advise if sensor problem or some other problem. Bleeding brakes with 2 people should be easy. re: One person to press the brake peddle and a different person to wrench its bleed screw (on further wheel hub working closer to Master Brake Cylinder).
Good luck...
2000 5.3L Silverado brake system is weak but everything is new Silverado_Dude Silverado 1 06-14-2010 07:12 AM
Announcement of TOYOTA(Guangzhou) on Camry's braking system defect ChinaCamryUser Camry/Camry Hybrid/Vista 3 04-27-2009 11:54 PM
service brake system (wont start?)help 4craigs TrailBlazer | Trailblazer EXT 1 04-16-2007 04:46 AM
Service Traction System & power door question Christophe Salvain Venture 9 01-01-2006 10:26 AM
2000 Blazer service 4x4 system warning light raiderman Blazer 5 12-21-2004 09:14 PM
