Having trouble figuring out why my truck won't start. I have had no problems with the truck till yesterday,I fill my truck up around noon made a couple of stops then drove home shut truck off now won't start..... I checked fuses, relays..... I'm thinking maybe fuel pump ??? Lots of cranking power just won't start ...
Re: 05 1500 Hemi Won't Start
When you turn the key to the on position, can you hear the fuel pump energize? Put the seatbelt on, open the door and turn the key to the on position and listen for a hum. Usually lasts 1-3 seconds. If not take a rubber mallet and tap on the bottom of the tank then re-try. This may move the fuel pump motor enough to get it to move. Will also answer your question on if it is the pump or not. |
im guessing no codes or lites came on, i was gonna say misfire or tps but sure that was codable
it was fuel pump
