Old 06-05-2007, 06:31 PM
rtmartin rtmartin is offline
97 1500, sometimes won't start with key..
Sometimes my truck will not start if i use the key, but if I use the remote start, it starts everytime..so does that mean I have a problem with the Ignition Switch or with the Lock Cylinder? sometimes if I move the column, it'll start, or atleast, i think that's what makes it able to start...any help is greatly appericated...
Old 06-05-2007, 10:14 PM
jocat54 jocat54 is offline
Re: 97 1500, sometimes won't start with key..
If your key is turning okay in the key cylinder then I would suspect that the ignition switch and /or the rod going to the switch. The igniton switch is located on top of the steering column under the dash, you might want to check that it is not loose or out of adjustment (there is not much in the way of adjustment). Since you say that if you move the column it will start it seems like the switch and or rod going to it.
2006 VW Jetta TDI Diesel (Super fuel mileage)
2004 Chevy 2500 6.0 Crew Cab
1993 Chevy K1500 5.7 (love this truck)
Old 06-06-2007, 05:54 PM
Thank you! I'll check it...and thanks again...
Old 06-06-2007, 06:26 PM
777stickman 777stickman is offline
The ignition switch has about 6 contacts in it, one of which is the crank contact. From reading your post I would suspect a wiring problem in the column, since you can move it and get it to work. Need to open it up and have a look...........Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-07-2007, 06:15 PM
bamadam bamadam is offline
When I bought my 95 K1500 used (3rd owner/ 76K mi)- it HAD been equipped for remote start but apparently abandoned or at least not passed on.
No problem for the first year and then I started getting intermittent problems just like you describe except it would also shut off if the column was tilted while running.
Got to looking around underneath and sure enough found a REALLY shoddy wiring job. The main (large red) wire had started arcing inside a badly crimped connector and lost contact if jiggled. Completely removed the old remote start unit and made good connections to all wires and it has run fine for 9 years now.
Good Luck
