Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-29-2010, 07:08 PM
Applianguy Applianguy is offline
So the intake gasket
So the intake gaskets took only about 30 minutes to replace and 4 hours cleaning all the carbon, grease and dexcool chunks. Every bolt tread needed cleaning add another hour for that. What a freaken nightmare.
Old 10-30-2010, 06:08 AM
old_master's Avatar
Advisor/Moderator
Re: So the intake gasket
The "crud" on the intake bolts is sealer. After cleaning the threads, make sure you put new sealer on the bolts, then use a torque wrench when tightening them.
You have to know how it works,
to figure out why it doesn't.
Changing the intake gasket Sikman Grand AM 6 06-23-2005 07:56 AM
Getting the Intake Gasket Repaired Eyebolt Malibu 1 06-20-2005 12:08 PM
need directions for replaceing the intake gaskets on a 3100 (3.1) shooter_911 Monte Carlo 1 07-18-2004 11:33 AM
does anyone have directions for replacing the intake gaskets on a 3100 (3.1) shooter_911 Malibu 2 03-21-2004 06:02 PM
does anyone have directions for replacing the intake gaskets on a 3100 (3.1) shooter_911 Lumina 4 01-26-2004 11:48 AM
