Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 10-28-2010, 05:27 PM
sigman1983 sigman1983 is offline
Bullet shot into van compartment
Ok this is my first post and it is an odd one. Long story short I shot a .38special FMJ bullet into the van. It entered 6inches below the steering wheel and I know it went through the metal frame behind the covering below the steering wheel. I cant see where it went from there. No wires or anything else is penetrated as I can see. No fluids are leaking. It steers,shifts and I dont smell any fluid smells. I cant find any detailed schematics to tell me what parts are in the area the bullet traveled. What should I do? I dont want to cause anymore damage.
Old 11-02-2010, 12:37 PM
dewaynep dewaynep is offline
Re: Bullet shot into van compartment
If everything is working OK you may want to leave well enough alone.
Old 11-04-2010, 09:19 PM
roadrunner2 roadrunner2 is offline
Don't want to cause anymore damage? Get rid of the gun.
The problem with doing nothing is not knowing when you're finished.
Old 11-21-2010, 07:37 PM
Blue Bowtie's Avatar
Registered Offender
If you can find the slug and the copper is still intact, it might not have done any real damage beyond the cosmetic. If it hit the lower bolster and penetrated there may be damage to the wiring in the steering column. If that was the path it may be worthwhile to pull the lower bolster and take a look.
That happens around here periodically and the rifle/shotgun deer season is coming soon. The damage can get pretty costly.
Water Leaks into Passenger Compartment krushmoto Caravan | Voyager 2 11-17-2007 05:09 PM
info on bypass of hoses to stop leak of heater core into pass. compartment schellfischy Thunderbird 10 02-21-2006 04:49 AM
Water leaking into passenger compartment LSC SS Galant 5 12-10-2005 08:55 AM
Winstar blower emitting smell into passenger compartment xoma Windstar 12 06-27-2005 07:59 PM
94 Lesabre - Water Leak into Passenger Compartment basebase LeSabre 2 03-24-2004 07:47 AM
