Old 10-27-2010, 08:58 PM
dj1111's Avatar
dj1111 dj1111 is offline
Any warnings before purchase?
I'm going to look at a 2005 Town & Country with 84,000 miles. It's a one owner in excellent condition and pretty much loaded with options. Anything to watch out for? Anything to avoid? I will be replacing a 1998 Chevy Venture. It has been a great van but has cost us a lot in repairs, head gaskets once, intake gaskets years later and transmission repairs to name the major ones. Thanks in advance.
Old 10-27-2010, 10:08 PM
b1lk1 b1lk1 is offline
Re: Any warnings before purchase?
These vans like to be maintained well and will require good service practices for long life. Get it fully checked and fix everything as soon as it is a problem. Leaving one issue will make it snowball. Otherwise, I personally LOVE my 2002 Grand Caravan and don't regret it for a minute, even after the few relatively minor issues I have had.
Old 10-31-2010, 10:37 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Bring it to autozone to have a code scan or bring your own if you have one. I recently bought a 2002 caravan. I didnt realize the check engine light (bulb) was removed. Turns out 02 sensor was bad but unknowingly I went to get it inspected and it failed.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 11-01-2010, 09:06 AM
Originally Posted by chevyn0va1 View Post
Bring it to autozone to have a code scan or bring your own if you have one. I recently bought a 2002 caravan. I didnt realize the check engine light (bulb) was removed. Turns out 02 was bad but unknowingly I went to get it inspected and it failed.
How did you repair it? I was under the assumption that it was a LED diode or soldered to the board as there is no access on the back of the cluster to replace any lights except the guage illumination lights and you'd be required to disassemble the cluster to get at that area as well.
Old 11-01-2010, 09:33 AM
Scrapper Scrapper is offline
AF Premium User
my moms got a 2000 and all i've done to it is put new front brakes on it and i keep her oil changed. i'd just take it to your m.c. and have them check brakes,rotors,exhaust,tires and tranny&moter mounts.good luck..... scrapper
Old 11-01-2010, 11:06 AM
chevyn0va1's Avatar
I was lucky My dash light is located in my "information bar" on top of the dash. I was able to pry it up (apparently loosened by the P.O. ) and flipped it to look in back. The circuit was printed with the name of the light. I called a dealer and then napa they had the light for like 2.50. It is a little light with its own circuit board bottom. The whole unit just twists in place like any other light. I can take pics if you want
Old 11-01-2010, 05:14 PM
mixbrix's Avatar
mixbrix mixbrix is offline
We have a 03 Grand Caravan with 150,000 miles on it's 3.3 engine. So far just normal things like brakes and tires. Have absolutely no complaints about it.
Old 11-11-2010, 12:06 AM
Cntrysthbst Cntrysthbst is offline
Send a message via Yahoo to Cntrysthbst
Well some people have luck with them and some dont. We have owned 2. One was a money pit, the other is caughting up. the 01 to 04 have the best interiors/seats, the 05's got cheap seats maybe because of stow and go, no infomation center either, they added it to the dash.. 80,000? most only have up to 80,000 warranty and then your on your own unless there is a recall. ask if it has the extended 100,000 warranty. Otherwise they (01-04) are nice..the 05's ok. we drove an 05 100 miles or so and seats got uncomfortable, they seem harder...
And most important - if you do buy it - i would really recommend putting automotiveforums.com (this site), on your desktop, there are some really good people here to help if you need it......
Old 11-11-2010, 08:28 AM
mikefaster mikefaster is offline
This is why I buy a Dodge MiniVan, I have no problem buying used, maybe a little dirty and such, but most importantly, WITH a known problem...
A lot of times, owners dump huge amounts of money into them, and then oops, the engine goes, or oops, the transmission goes, then I buy it for under $1000 and fix it myself... Chances are they fixed everything else!
Old 11-11-2010, 10:20 AM
I have read that to, the Dodge GrandCaravans do have a better reliability than Town and Country, by far...
Old 11-13-2010, 07:54 PM
dj1111's Avatar
I've looked at a lot of T&C and Caravans in the 2004~2006 years and am amazed at how many of them are starting to rust already. I'm looking to replace my 98 Venture who's rocker panels are almost completely rusted away. The Dodge and Chrysler vans are starting to rust in the exact same place my Venture did, right in front of the rear wheels. I looked at a 2006 tonight and would estimate in about 2 more winters of salty roads there will be a significant hole on the bottom of the rocker panels and probably creeping up the outside of the sheet metal. The rust on the drivers side was actually bulging the metal and paint in that typical volcano like fashion, about 1" in diameter.
Old 11-13-2010, 08:00 PM
I just replaced those sections on both sides of my 2002 and the passenger side rear wheel arch had one of those blisters which required replacing about 3" of sheetmetal. No big deal really for me as I have friends with body shops, but even on your own it is not an expensive repair. This seems to be very common with all minivans.
Old 11-13-2010, 08:07 PM
Well the north and northeastern vehicles can be prone to that...
This is why a lot of people get their car washed every week in the wintertime... It helps...
My suggestion is to try to find a van WITHOUT undercoating... It REALLY doesn't work the way it should and whoever the dealers use (or if they do it themselves) to DO the undercoating, don't usually do a good job...
Many times the undercoating RETAINS that salty water because the undercoating has sort of, "loose ends", that will collect water and trap it...
Every time I see a van without undercoating, it tends to be pretty clean...
Maybe that can be a starting point in your search, and maybe what I say can be collaborated...
Good luck
Mike
Old 08-07-2011, 07:03 PM
dj1111's Avatar
We finally ended up purchasing a 2005 Caravan. What we found was an SE that looked more like an SXT. Grand Caravan, 75,000 miles, roof rack, 16" alloy wheels, dark tint glass, nice pin striping, quad captains chairs, front and rear heat and air, etc. But no power sliding doors or power lift gates or uncomfortable stow and go seats or other useless options that cost you money and gray hairs. And without stow and go you get a full sized spare tire.
Old 08-10-2011, 03:06 PM
I'm on the fence about stow and go. I'd love the ability to stow the rear-most seat when needed, but it really isn't that big of a deal to pull it out since I only have 2 kids and my wife so I really only need the 4 chairs most of the time.
a few questions before purchasing 2002 Alero axemurder Alero 4 05-19-2008 12:52 PM
How do you know for sure a car has not been stolen before purchasing? mlinn Car Buying Q&A 3 09-02-2005 03:16 PM
Questions before purchasing an FC MikeWz RX-7 12 08-08-2005 02:13 AM
1949 Chevy Convert. Qustions before purchase JaBuBa Engineering/ Technical 1 03-25-2005 09:17 AM
