Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 10-26-2010, 06:28 PM
jima4624pY2 jima4624pY2 is offline
bank 1
can some one please help me out i need to change 02 sensor bank one sensor 2 bank 1 is on the right side?????????? thanks
Old 10-26-2010, 06:53 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: bank 1
Out of curiosity, why do you think you need to change one particular O2 sensor? Many of the O2 sensor codes just indicate that the sensor is reporting a particular parameter of interest, not necessarily that the sensor itself is bad. I'd hate for you to invest in new sensors only to find that the real cause is a $3 vacuum hose or something.
But, to your original question, yes, bank 1 is the bank on the passenger side of the car. Sensor 2 is the sensor after the catalytic converter.
-Rod
Old 10-26-2010, 07:58 PM
Re: bank 1
-Rod
i check and the code was p0136 and it says 02 sensor bank 1 sensor 2 does that not mean the sensor is bad if i am wrong i am all ears thanks
Old 10-27-2010, 12:40 PM
shorod's Avatar
SHO No Mo
Re: bank 1
That code does not necessarily mean the sensor is bad. It could be, but the code could also be due to a leak in the exhaust near the sensor, a wiring issue for the sensor, or a dirty/corroded connector in the O2 sensor circuit. If you have a scan tool that can monitor the O2 sensor datastream it may help you determine if it's likely a wiring issue versus a sensor issue.
-Rod
bank 1 banks 2 o2 sensors kreep 7 Series 2 03-09-2007 10:19 AM
1997 Lean bank 1, lean bank 2 Baja SS Jimmy 5 03-08-2006 11:00 AM
lean fuel bank 1, lean fuel bank 2 hotpursuit Sienna 4 03-07-2006 07:23 PM
Bank one and Bank 2 pre cat? texasdiver Cougar 1 11-22-2004 11:23 AM
Bank 1 & Bank 2 TuBlaz Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 10-27-2004 01:21 AM
