Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 08-28-2005, 09:04 AM
kreep's Avatar
kreep kreep is offline
Send a message via AIM to kreep
bank 1 banks 2 o2 sensors
I was just wondering which side was bank one and which side was bank two on a dual exaust 740il? The reading w/ the obd2 tool said that the one of the 02 sensors were bad on bank two, just I don't know which side that is.
Be more concerned with your character than with your reputation... Character is what you really are, reputation is mearly what you are perceived to be.
A good attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.
Old 03-08-2007, 02:27 PM
hwade hwade is offline
Re: bank 1 banks 2 o2 sensors
Make sure it not the air flow meter first, i was told by the local dealer that the air flow meter could make the o2 sencors seem bad
Old 03-09-2007, 10:19 AM
lincolnmaster80 lincolnmaster80 is offline
hwade, not all problems are caused by the air flow meter. When the diagnostics come back with an O2 error, that's usually a good place to start. Although, a good MAF cleaning isn't a bad idea every now and then especially if the air filters haven't been changed in a while.
To test, jack up the car, usually when the engine is warm, unplug an O2 sensor, turn the car on. If the problem gets worse, turn the car off, plug that O2 sensor back in, unplug the other O2 sensor, turn the car on and if the problem doesn't change, then you know which sensor is Bank 2.
If I'm not mistaken, bank 1 is on the right hand side. At least, on my V12 cyls 1-6 are on the right, as spark plugs 11 and 12 have been refered to being on the left.
Also, do you notice if your exhaust smells 'normal'? An indication of a knackered O2 sensor is usually a 'foul' exhaust smell, it makes your eye's burn and you gag and gasp for air more easier than 'normal' exhaust. There is also an error code of 'mixture too rich' if an O2 is bad.
(NOTE: This thread was posted over a year ago!)
1990 E32 750iL --> Pictures
Production: 02/1990
Johan and Sean's E32 Page - Repairs and How-to's
E38.org - Information and tech tips for BMW's
Shogun's E32 Tech-Tips
Gale's Repair Page
ETK Online
