Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-12-2005, 08:16 PM
qball21 qball21 is offline
95 bonneville antifreeze odor
My 95 will give a smell of leaking antifreeze but can not find a leak, I have checked my levels and do not seem getting low my tempture gauge doesn't run hot it only does this after driving about 30 min and the smell is strong whn stopped when mmoving is nothing. Anyone have any idea what may be the problem
Old 02-13-2005, 12:18 AM
festpace festpace is offline
mine was because the bypass connector from the water pump to the intake manifold broke. The factory piece is made of plastic and I smelled antifreeze for a month before finding it - apparently it had a crack in it allowing antifreeze to seep out and burn off for quite sometime. After moving the alternator out of the way and removing the hose I had to heat a chisel and melt it into the broken piece then let it cool and backed it out by turning it counterclockwise. The guy at NAPA was very familiar with the replacement part- new peice with hose was about $16. This may not be your problem but it turned out to be mine - not sure how many years they used the plastic "connector."
Old 03-12-2005, 02:59 PM
Megamister Megamister is offline
Send a message via Yahoo to Megamister
I went one step better and instead of replacing with the same plastic piece, I went to the local hardware store. I found a brass pipe bushing or something with the same threads, then a brass hose barb that threaded into the bushing. A little teflon tape on the threads and it will never break off again.
