Old 10-25-2010, 11:55 AM
Trio3b Trio3b is offline
Send a message via AIM to Trio3b Send a message via Yahoo to Trio3b
Your two cents . . . .
'99 Camaro 3.8 V6 116k miles. Think a bearing turned (maybe) Just started yesterday. Pretty sure rod knocking and ticking in the upper end. Car runs, no smoke . oil pressure 60 running to 40 when idling. Either way it's not good. Debating whether to dump car or get a rebuilt /new engine. Will not be buying new, just another used vehicle. Just want to see if I'm thinking this thru properly:
Pros to keeping car:
1. Interior / exterior in excellent condition
2. Tranny recently serviced - he said it looked good
3. I know I'll have a new motor
4. I can't stand car shopping
5. Might get someone else's problem if I buy another used vehicle
6. Mechanic (who I trust) wants $2500 to $3000 / will give 3 yr 100k mi. warranty
Con's to keeping car:
1. gas gauge doesn't work but we've figured out a routine so no biggie
2. No one can shut off the check engine light. It has been traced several times to the cat converter. (it has all new O2 sensors/ heaters etc. ). I've been told by several shops and exhaust shops that the only way to fix is either put in a $1000 OEM cat or buy an after market cat every couple years just before inspection time. I have an IOU with the muffler shop to put in a new after market cat due to the old one "failing codes" within warranty so I WILL get a new cat out of it. If not I can tolerate a new $200 aftermarket cat very 2-3 years.
Kid likes the car. And did I mention dad doesn't like shopping?
Any thoughts?
Thanks
Old 10-26-2010, 12:00 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Your two cents . . . .
My 2 cents.........
As a fellow dad, seeing the relatively low mileage on it, I'd be going to the store, grabbing a case of beer to consume while I sit om my tookus and 'supervise' the lad replace the engine that it sounds like was neglected. 3.8's are pretty good motors and can last a long long time, again, kind of low miles on it.
Old 10-26-2010, 02:03 PM
Originally Posted by wrightz28 View Post
My 2 cents.........
Thanks. I'm going to go over to engines forum and see if we can replace the crank with a reman w/matched set of bearings. Also going to see if this can be done with engine in car.
I realize this is very high risk but seeing as how the engine is considered "shot" anyway, what more damage can I do? I'm exploring all options as finances are not good right now. I figure IF I can get to the crank from under and if the bearing was not cheese grated and spread throughout the engine and that the offending rod surface was not egged I would be willing to risk a couple hundred $$ and two weekends to try a reman crank. Compared to $3000 for a new motor . . I am thinking.. . but those are a lot of IFs . . . . but the vehicle was only driven about 20 mi. after the knock started and we kept it below 2k RPM. Maybe I got lucky.
Thanks
Just my two cents - Brakes ryanszpara Silverado 4 09-04-2006 09:33 PM
Transfer case fluid change, my two cents rjirvine Silverado 2 12-08-2005 10:24 PM
Cleaned throttle body and egr tube, my two cents rjirvine Silverado 6 05-30-2005 12:26 PM
my two cents... sdshow '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 64 10-15-2004 01:49 PM
my two cents (the beginning) dbebesi Politics, Investments & Current Affairs 32 09-29-2004 10:19 PM
