Old 10-23-2010, 11:43 PM
x3zell x3zell is offline
89 si window problem
hey every one , im new here and have asked on other fourms.. i have a problem i have A 89 Si and my drivers side window wont go up and there is noting...i have JDM conversion on it ... any idea's ??? and where would i get parts thanks
Old 10-24-2010, 08:51 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: 89 si window problem
Thats a little vague, can't help you much with that.
JDM Conversion? Forgive me, I don't keep up with JDM conversions...are the windows power? if so that explains a little more and I might be able to help out, could just be the motor, could be wiring or relays. Best way to find out is to take the door apart, unplug the motor and apply 12v to 1 pin and ground to the other pin, should move either up or down, flip the 12v and ground around and it will go the opposite. If you get nothing out of it, the motor is shot. If it moves both ways, its wiring or relays.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-24-2010, 10:10 PM
crx's never came with power window's its JDM conversion... most likely it could be the motor ill have to check it out.. when im out where the car is but thanks for the info
Old 10-25-2010, 04:17 PM
Tony's Avatar
TLD Member #1
Or its simply jacking the window motors from a Sedan....Again, I'm not all for the JDM stuff, more of a function over form guy.
Just test it like I mentioned above, it will tell you which part of the circuit your having issues with. If it happens to be the relays/wiring, you will need a schematic and start probing plugs in it.
Tony
Old 10-25-2010, 09:00 PM
thanks for advice greatly appercatied
Old 10-25-2010, 09:41 PM
Tony's Avatar
TLD Member #1
Electrical problems are tedious but aren't that hard to deal with. Just a lot of testing here and there. 12v + ground is the easiest way to test, Ohmmeter works as well if you have access to one.
Tony
Window problems tizzlestick Grand AM 0 09-09-2010 07:20 PM
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
2000 323i Rear Drivers Side Window Problems dereistic 3 Series 0 06-11-2010 05:06 PM
1990 Mercury Sable power window problems joannslaw Sable 1 05-16-2010 04:25 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
