Go Back   Automotive Forums Car Chat > Buick > Lucerne
Old 10-23-2010, 08:43 AM
old.driver old.driver is offline
Question Rattle in rear end.
I have a rattle in the rear of my 2007 Lucerne, I have made everything secure in the trunk including the spare tire and jack, I believe that it is the rear brake calipers rattling, for when I step on the brake the rattle stops, I only hear this on some payment joints, it is not noticeable on all roads.
Old 02-05-2011, 02:17 PM
Rickpatbrown Rickpatbrown is offline
Re: Rattle in rear end.
Check the trunk spring mechanism. It's two rods that provide the needed tension to open the trunk. Mine was making the rattling sound and I had to stuff a rag between the two bars. It is a ridiculous design in my opinion. The two bars clang together from road vibrations. I think that there was a plastic tie that was supposed to keep the rods together, but did not accomplish this.
Old 02-05-2011, 03:40 PM
consultIII consultIII is offline
inspect the rear brakes. if all is secure apply some disc brake quiet to the back of the rear pad shims.
Old 04-21-2012, 08:06 PM
pcmos pcmos is offline
Send a message via AIM to pcmos
The rear end rattle in mine turned out to be the torsion bars for the trunk as mentioned above. I slit a piece of rubber hose lengthwise, making sure it's inner diameter was about the same as the outer diameter of the torsion bar. After slipping the rubber hose over each bar where they make contact towards the center of the trunk, I zip tied them in place and the rattle / clanking noise disappeared. You may want to give that a shot because it is a really easy fix. LeSabre / Park Avenue used the same basic design for the trunk torsion bars, something is slightly different on this one and they make noise for some reason.
howling in rear end rezology M Bodies 2 08-14-2010 02:45 PM
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
Rear end noise fastlane85023 Mustang Problem Diagnosis 4 11-29-2009 07:39 PM
95 yukon winding noise in rear dadof2gurls Yukon 2 08-31-2009 06:49 PM
