Old 10-21-2010, 07:05 PM
fire24resque's Avatar
fire24resque fire24resque is offline
Leveling Kit / Rear Blocks Suggestions
2001 Silverado 1500 4x4 ...
I want a lift but don't want to put the money into a full suspension lift, not much just a little (2.5-3"). I was thinking of getting a 2.5 leveling kit for the front and either leaving it there or giving the back a 2" boost or so. Any suggestions on the front, leveling kit, blocks?
What brands/types have you been successful with?
Thanks in advance
2001 Silverado 4x4 - 4.8 V8 - Hankook Dynapro ATm RF10s, 265/75/16
K&N FIPK - Flowmaster 50 Series 3.5" Duals
4-Headlight Conversion Kit - Billet Grille
90 Watt Nova Strobe Pack
2.5% Limo Tint -
Check Out Pictures and More Here
http://www.cardomain.com/ride/2131569/1
Old 10-22-2010, 11:46 AM
j cAT j cAT is offline
Re: Leveling Kit / Rear Blocks Suggestions
Thanks in advance
you cannot lift this vehicle 3inches and ignore the drive shaft angles.
this is not cheap. when the angle of the U joints CV joints is increased these componets fail. to correct for this is costly.
If your vehicle did sag you can bring the height back by adjusting the torsion bars . this is correct when the CV joints are straight.
If you have a heavy load in the bed the use of air bags works great to maintain a level vehicle and extend drive train componet life.
Old 10-22-2010, 11:58 AM
I did crank the torsion bars 6 turns each about 5 years ago and leveled the front. It since have sagged back down, I'm assuming it was just natural metal flex and they twisted back. Is it safe to crank them anymore, or what are my options?
2.5% Limo Tint -
Old 10-22-2010, 12:06 PM
If you operate this vehicle with bad shocks this will damage these torsion bars. It is possible to adjust for a bar that is twisted .
so your CV joints on level ground are not straight ?
Old 10-22-2010, 12:08 PM
Everything looks straight to me. Like I said, 6 turns five years ago leveled it out. It has sagged back down to stock height since then, again I'm assuming this was just the torsion bar metal "wearing" due to the load. Can I re-load them safely with a few more turns is what I'm asking.
2.5% Limo Tint -
Old 10-22-2010, 01:11 PM
my 2000 sil 4X4 I had to adjust about 2 turns after vehicle break in to level off the front end .. that was 9years ago. since then it is still the same height. I do have bilstein shocks and the originals where still good when I replaced them about 6yrs ago.
six turns is alot . could be you need new bars or componets to the bars need replacing. your truck must ride very harshly on the up bounce as it will hit the stops when too high ..
Old 10-23-2010, 09:21 PM
Elbert Elbert is offline
they do make leveling kits for some year model trucks. These generally only are for the front. You raise the front end to match the rear. Don't do anything to the rear suspension.
Search the web for leveling kits...I would generally avoid doing this, but if you proceed it would be good to know what "kits" work well. Once you screw with some of hte sterring geometery its really a challenge to get your "drivability" back.
The easy leveling kits apply to trucks with coil springs..... IFS trucks = not so easy.
with IFS generally I've seen new "keys" that are used to alter the lifit at the torsion bars.
Your steering and alignmetns can really be screwed by some of these setups.
Elbert Clarke
Old 10-24-2010, 12:45 AM
bigbadram51 bigbadram51 is offline
Most suspension kits that advertise 6" of lift only drop the front diff 4-4.5 inches. They get the rest by cranking the torsion bars. From my experience running with a couple inches of crank is not that big of deal (60k+ miles with lift, 120k+ total miles) on factory CV's. You can find leveling kits (cognito makes one) that have new uca's that help correct upper ball joint angle, and also come with bolt in ball joints, makes for an easy switch. I do agree with everyone that says it will wear out parts sooner...which is true...but they are parts that wear out anyways. The only suspension components ive had to replace in 4 years are lower ball joints, and a set of tie rods (but that has more to do with the 35" tires.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 11-15-2010, 01:26 AM
4x4junkie 4x4junkie is offline
check out the information on http://chevytruckworld.tenmagazines....ticle&aid=3693 it may help you decide what you want to do. this article deals directly with different types of lifts.
Old 11-30-2010, 10:10 AM
Streetwise's Avatar
Streetwise Streetwise is offline
Send a message via Yahoo to Streetwise
I cranked my bars as far as they would go and it leveled the front end even with the rear. It made no difference in handling or suspension. Rides and drives the same. I had to adjust the head lights, however.
Old 12-01-2010, 12:29 AM
a simple reminder: anyone attempting to adjust the torsion bar adjustment screws on their truck should first jack up the front end and set their truck on jackstands before adjusting the torsion bar settings, adjusting the torsion bar height without raising the vehicle can cause the threads to strip out for the bolts and create damage that will be a real pain to repair, and you can rough measure while under the vehicle because on most silverados approximatly 1/4 of an inch of adjustment at the bolt end on the torsion bar equals about 1 inch of height at the wheel well.
Silverado Leveling kit Silverado_Dude Silverado 0 08-14-2009 08:46 PM
Lift or Leveling kit? searcher21 F Series 0 06-09-2004 10:24 PM
Superduty leveling kit Polaris101 F Series 1 02-26-2004 08:51 PM
Leveling Kit mattZ71 C/K 0 02-15-2004 07:15 PM
engine block suggestions for 66 Riviera WHIZ Car Modeling 3 02-06-2003 02:15 AM
