Go Back   Automotive Forums .com Car Chat > Ford > Crown Victoria
Old 10-21-2010, 07:12 PM   #1
1996Chreokee
2000 crown victoria PI oil in radiator
Hi I am looking to buy a 2000 CVPI with 100k miles on it. It is really clean and he wants 900. Problem being there is oil in the radiator. No coolant in the oil. He said a ford tech told him that is was the oil cooler, so he said it cost him 400 and he changed it but there is still the problem of oil lose into the radiator. are these cars prone to head gaskets? Are the a real head and expensive repair? Is there a way to check to see if it is a head gasket without a pressure test? bubbles in the radiator??? or running real rough?
1996Chreokee is offline   Reply With Quote
Old 10-21-2010, 07:34 PM   #2
way2old
TOKEN HILLBILLY
way2old's Avatar
Re: 2000 crown victoria PI oil in radiator
You can get a kit that checks for exhaust gasses in the coolant. Usually when the 4.6 loses a head gasket, it leaks outside not in. Not saying that is not your problem, but it is not really common.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
Old 10-21-2010, 10:38 PM   #3
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
The oil cooler does not have any point where the oil and coolant can mix. If oil got into the coolant, than it is a high probability of a head gasket issue.
I just started noticing my driver side head gasket leaking a bit of coolant into a cylinder based on the white smoke out of the exhaust on occasion. Prior, it only weeped coolant from the head gasket to the valley.
I'm not sure of the model year or manufacture date range but I'm pretty sure the MY2000 is affected by a problem during the manufacturing process where metal particles got between the head gasket and mating surfaces and can cause the weep and premature headgasket failure. But like way2old said, these engines mostly weep externally unless it was severely damaged such as in the case of being overheated.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
1998 Crown Vic Hesitats after wash fatcat0915 Crown Victoria 5 11-11-2009 04:58 PM
Help Oil Cooler Lines oscales Tahoe 4 09-09-2009 09:44 PM
For Sale Crown victoria oil cooler cfrank2 Parts for Sale 0 06-18-2009 04:28 PM
2000 Crown Victoria P71. Need Help Please!!` drewallen42 Crown Victoria 2 05-29-2007 08:34 AM
New Project: 1999 Ford Crown Victoria FBI Car CamaroSSBoy346 WIP - Street 12 07-12-2003 11:54 PM
