Old 10-21-2010, 02:37 PM
gscontr gscontr is offline
abs/brake question
replaced the pads and rotors and also the master cylinder on my 98 grand voyager. fluid came out dark and stunk. The pedal goes down as if there is a fluid leak but none visible. bleeding over and over helps a little but no fix. Does this sound like an abs problem? No abs light... no other indications, pedal feels like a bad leak. thanks for any help.
Old 10-21-2010, 02:43 PM
danielsatur danielsatur is offline
Re: abs/brake question
Need to flush old contaminated brake fluid, and bleed system.
see http://www.youtube.com/watch?v=L0oUejw5Edc
Also see simular threads at the bottom of your thread.
Old 10-21-2010, 04:08 PM
Thanks for the help, flushed a few pints of new fluid through the lines and that did the trick. I've never seen old fluid that bad before, guess what they say is true..."always use dot 3 from a sealed container". Thanks again. chris
ABS Hydraulic Unit tips for rebuilding bertpalm General Discussion 0 01-16-2010 07:00 PM
ABS /Brake Questions for Alero owners thelethalblow Alero 4 03-17-2008 01:16 PM
ABS Brake Question On 98 Olds Intrigue Frontrunner Intrigue 3 02-01-2007 05:24 PM
90 Olds Trofeo ABS brake question OverBoardProject General Discussion 0 03-11-2006 12:27 PM
ABS/ Brake Question AaronAlbZ24 Cavalier Problem Diagnosis 2 04-02-2005 08:00 PM
