Old 01-29-2007, 06:34 PM
Frontrunner Frontrunner is offline
ABS Brake Question On 98 Olds Intrigue
When I hit a bum the abs kicks in and its hard to stop. Im thinking a wire is loose or a sensor is bad. Just thought I would see if anyone else has had this problem. The light comes on as well both the ABS and Traction. I thank anyone with an opinion in advance.
Thanks
Old 01-29-2007, 06:47 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: ABS Brake Question On 98 Olds Intrigue
Front or rear? It could be a bad strut allowing the tire to bounce after hitting a bump..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 01-30-2007, 07:40 AM
prsoto21 prsoto21 is offline
Check the wires going into the Hub Assembly behind the brakes. I had a loose connection which triggers that problem.
Old 02-01-2007, 05:24 PM
Thanks guys. It ended up being a loose fuse in the side panel....lol...Im just glad thats all it was.
Thanks again
