Old 10-21-2010, 06:29 AM
sheetalstyle sheetalstyle is offline
is car servicing important
What according to you is the ideal time interval to go for car servicing ?
Old 10-21-2010, 08:58 AM
Scrapper Scrapper is offline
AF Premium User
Re: is car servicing important
one thing you want to do is keep your oil changed at 2500-3000 mls. and if your loosing gas milage your plugs,air filter,wires,gas filter even keep an eye on tire pressure don't go by what it sais on tire go by what the car sais to run them at that's for milage and wear and tear also and put some seafoam in it about once a moth. i'm sure others on here will tell you more.
Old 10-21-2010, 10:56 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Refer to the owner's manual for this info...use the "severe" service interval because that's about what everyone's driving habits fall into categorically. For newer vehicles, the old 3,000-mile oil change interval is overkill and primarily for the benefit of the shops that do them.
One thing I will debate are the so-called "filled for life" fluids. I can't see how any carmaker has engineered something so well that a fluid is good enough to last the whole life of a vehicle. Lubes breakdown, oxidize, become laden with particulates, fine metal shavings, etc. Replacing with fresh fluid keeps these contaminant levels down and replenishes the fluid's protective properties.
Case in point: 2003-up Ford Explorer/Mercury Mountaineers have sealed transmissions...no drain and no fluid level dipstick. These have had bad reputations for transmission failures. My gut would say 50k miles for transmissions, 100k for differentials and transfer cases, sooner if the vehicle is used for towing regularly.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-22-2010, 12:15 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
The owner's manual has service intervals. They are set up for two things: 1) to be VERY conservative so they cover their a$$es when it comes to warranty repairs, and 2) even MORE conservative to make you think you have to spend money at the dealer for service.
There is no set "service" time. Oil changes can be anywhere from 2000-15,000 depending on the vehicle, its use, and the oil you use. Tire rotation is heavily dependent on FWD/RWD/4WD as well as the type of tire and how you use it. Air filters might need to be changed every 2000 or every 100,000 depending on how you use it.
Ask some more specific questions
Dragging people kicking and screaming into the enlightenment.
Old 01-09-2013, 09:00 AM
Carmichael Carmichael is offline
Yes servicing is important and you want to follow the manufacturers handbook to keep your motor from dying on you. Your time is better spent looking for a good garage than pondering whether to service or not.
A motoring mechanic with many years of toiling over many vehicle makes. I very much enjoy reading blogs and forums and assist with car service issues where possible.
Old 01-16-2013, 07:24 AM
RoyalRose RoyalRose is offline
Regular car servicing is important for the performance and the long run of a vehicle.
[Spam signature removed by moderator]
Anyone ever bought a rental/service loaner car? cgruita Car Buying Q&A 11 02-27-2010 01:12 AM
Car Buying help and service trim250 Car Buying Q&A 2 08-04-2009 10:58 PM
american cars or import cars better?? publicenemy137 Car Buying Q&A 15 01-24-2004 10:06 PM
muscle car or import ? mngse00 Street Racing 21 01-23-2002 06:58 AM
Tags
cars , maintenance , services
