Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 10-21-2010, 01:33 AM
piyush1 piyush1 is offline
Banned
Valve Adjust / Clutch Creak
I had someone looking at my 01 CRV that I advertised for sale. Looker told me CR-V's need valves adjusted every 60K. Book says don't do it unless they are noisy, only do it when timing belt is changed at 105K.
Also, he noticed the clutch linkage creaks. You have to have engine off and radio off and hold your breath to hear it. I can't tell where it comes from. My daughters Civic creaks way more. I know it's trivial, and I never noticed it before, but what is it? Could be the shaft that pushes the master cyl, or the switch rocker, or the hinge, but I I got under dash and blasted everything with lube spray, and it still creaks.
Need help with 327 valve adjustment gr8hse67 Chevrolet Classics 6 04-04-2010 03:28 PM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 07:22 PM
valve adjusting??? 95vteclude Engineering/ Technical 14 09-19-2004 01:39 AM
valve adjustment? rossman Maintenance 4 11-27-2001 11:47 PM
What Is Valve Adjustment For? DOHCGSR Integra 7 09-12-2001 02:11 AM
