Old 10-20-2010, 09:11 PM
boilrman boilrman is offline
95 astro no start
My astro wont start. Checked fuel pressure 61 with key on Holds 59-60 for 5 min plus. New wires, plugs, rotor and cap. Checked ignition module, pick up coil and coil, all are good. Also checked coolant temp sensor- good. Van will run with a shot of carb cleaner down the tubing. Pulled upper intake and checked for wash out, none noted. Keyed on pump - no leaks found. Pulled poppets from holes and cranked engine over, no fuel coming from poppets. Spider is only 2 years old. Van has 200K on it.
Seen alot of info saying people replacing fuel pressure regulator. I dont see where you can purchase it alone. Is there a way to check the spider to see if it is good? How about checking the regulator?
Old 10-20-2010, 10:09 PM
Scrapper Scrapper is offline
AF Premium User
Re: 95 astro no start
take fuel filter line off coming from tank side and see if gas is pumping up to filter first.
Old 10-21-2010, 04:16 AM
I put in a new filter also. I get 60 PSI constantly at the shrader on the fuel line located at the rear of the intake. It has run several times and several miles, in between the changing of the pump, then plugs, wires, rotor, cap and now the no start.
Old 10-21-2010, 08:32 AM
AF Premium User
can you check your spark and see if it;s blue or yellow? if yellow no good you need blue.
Old 10-21-2010, 11:03 AM
it did seem a bit yellow to me, but what would be causing it if the coil, pick up coil passed the Ohms testing and ignition module passed testing at auto parts store?
Old 10-23-2010, 09:40 AM
I only have 6 volts to the wiring for the spider when the key is on or starting. Can someone tell me where my issue may be?
Old 10-23-2010, 04:28 PM
Well on the hunch of the salesman at AZ. I installed an ignition module. I turned it over and the injectors squirted. Put everything back together and it is still running.
I had the Module checked and they test ran it 5-6 times and it tested good every time.
89 Astro starts fine, then stalls. Busted 4.3 M Bodies 6 05-10-2009 09:26 AM
1990 astro starts in gear sjbckv M Bodies 2 12-31-2004 01:36 PM
astro starting problem when wet esibelius M Bodies 2 09-27-2004 07:26 PM
1992 Astro starting problems? joeshannallie M Bodies 0 06-01-2004 12:09 AM
