Old 12-23-2003, 08:45 PM
Busted 4.3 Busted 4.3 is offline
89 Astro starts fine, then stalls.
I have a 1989 Astro that starts just fine, and idles normally for usually less than a minute, and then starts to bog, and will stall if I don't give it a shot of pedal. This is a used vehicle that I just picked up in this state, so I don't know anything about its history. I would like to know if anyone could suggest a logical plan of attack to figure this one out, or if someone might even have a good guess as to what might be causing this problem. Thanks for any help anyone can provide.
Old 01-01-2004, 05:26 PM
drparkwood drparkwood is offline
Check the EGR valve by pulling it off and seeing if it is gum'd up. Also the O2 sensor could be toast.
Old 01-12-2004, 06:40 PM
Unhappy Thanks DrParkwood. I need more input though.
I have tried replacing the EGR valve with another known good one, and it didn't do much for it. I don't want to purchase an O2 sensor to try on speculation. Is there anything else anyone can think of trying before I spend way more money than I have on an O2 sensor. Any help will be greatly appreciated.
Old 01-13-2004, 04:36 PM
RABarrett RABarrett is offline
Re: 89 Astro starts fine, then stalls.
If the goal is to minimize expenses, a good diagnosis is in order. The first thing to check is to do a scan for codes. Then check the fuel pressure. It should be between 9-13 lbs. Start with that and we'll go from there. Ray
Old 01-18-2004, 02:05 PM
JohnnyO JohnnyO is offline
I'd check the fuel filter first.
Old 05-31-2004, 03:53 PM
ivanc ivanc is offline
I had a similar problem and I had a a Service Engine light. It turned out to be the Engine Temp Sensor which had gone open telling the computer that it was -40 deg. It was dumping in so much gas that the engine would flood and not run.
Ivan
Old 05-10-2009, 09:26 AM
diggin diggin is offline
Folks , please take a look at the date of the post you are replying to. This post is 5 years old !!
99 GTP starts and then stalls buckeyeguy Grand Prix 2 03-16-2009 07:38 AM
starts fine then warms up, then no start word110 Problem Diagnosis 6 03-14-2009 07:43 PM
92-GC w/3.3 v6--after 2 months sitting, started fine,, then,,, 3DRCpilot Caravan | Voyager 1 05-18-2006 01:37 AM
2000 Grand Marquis starts fine then stops hvgonzal Grand Marquis 6 07-13-2005 01:38 PM
'93 Bonne SSE w/sc starts fine then dies tug_boat62 Bonneville 7 07-01-2004 08:50 PM
