Old 10-20-2010, 05:36 PM
m.glisson003's Avatar
m.glisson003 m.glisson003 is offline
Dificulty of engine swap
I have a Honda Del sol and I was wondering how dificult it would be to put in a competely different engine. It wont be any bigger, if anyhting its going to be smaller.
Michael Glisson - Semper Fidelis
Old 10-20-2010, 11:47 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Dificulty of engine swap
If its a different Honda engine, it will be difficult. If it is a completely different engine, rank it up there with "what-was-I-thinking" type difficulty.
RWD cars are simple - weld in what you need and make a driveshaft to connect the front to the rear. FWD cars are massively difficult to swap engine types.
Dragging people kicking and screaming into the enlightenment.
Old 10-21-2010, 12:10 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
You say the engine would be smaller - do you have an particular engine in mind ? If so - what and why ? Is your present engine worn out or ...what ? As curtis said , swapping fwd engines means normally having to swap the entire drive train ( transmission , axles , and differential as well ) unless the new engine will fit the present drive train . Also the new setup would require modifying the shifter , wiring , and all the incidentals that make vehicle work . It can be done but it's a major job ! Keep us updated !
" Sometimes I grow so tired "
Old 10-21-2010, 04:40 PM
Well my goal is to strip the car of any unnecessary weight, which is already done, and then modify the current engine or swap it out for another engine for better economy. No I dont have a particular engine in mind. The engine will need to be swapped soon anyways because its on its last legs.
Old 10-21-2010, 04:46 PM
oldblu65's Avatar
If you're looking for the lightest weight and greatest fuel economy you can get , then the simplest and cheapest way would be to rebuild the original engine . That way no modifications would be needed and spare parts would be easy to obtain . The reduced weight would make the original engine feel more powerful as well as get better MPG !
Old 10-21-2010, 04:52 PM
Okay. When rebuilding an engine what are the major things I should be doing? I've never rebuilt an engine before, the most in depth I've gone is engine swap and head gasket replacement.
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
