Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 10-20-2010, 08:03 AM
Panoz Paul Panoz Paul is offline
oil cooler or not
I've run into two very opposing views ; engine builder states he does not believe in oil coolers ... He's builds many full race set-ups for the dirt guys & claims that theres not a harder run motor !!!
Mechanic / road racer says BS ; cooler in !!! This ties into the fact that this motor run flawless on the dyno w/out & lasted 10 minutes in the car w/ the cooler ... Verified line configuration ; correct "at dis-assembly ?!?!" ; new lines & cooler also installed prior ... I might follow the engine builders advise ... I can't stomach another melt down ...The cost of the "second" re-build between these two guys is not resolved ; I'm watching from the side lines...Any thought ??? Thanks/Paul W.
Old 10-20-2010, 10:50 AM
Werling Werling is offline
Re: oil cooler or not
Get the oil cooler. On a hot day running 20 to 30 min the oil can get pretty hot. at 300 plus temp you are over the edge.
Old 10-20-2010, 11:30 AM
Panoz26's Avatar
Panoz26 Panoz26 is offline
IMO - Oil Cooler.
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 10-20-2010, 02:11 PM
boothkc boothkc is offline
I can't think of any reason you wouldn't want an oil cooler?? Our GTS runs in Northern California in the summers we see track air temps of 105+ and even with this engine oil temps during race never seem to get above 240 and often much lower. Gives you a few more quarts of oil in the system too. Reliability isn't an issue with a good cooler and good lines.
Also, easy to plumb in an Accusump which may be a good idea.
I guess you could run it for a bit and see how it does and make sure it is together correctly then hook up the cooler?
Kevin
Old 10-28-2010, 10:12 AM
panozdoc panozdoc is offline
Authorized Vendor
OIL COOLER A+ idea.... Need one?
Old 10-29-2010, 02:40 PM
eric1h eric1h is offline
Only time i could see an oil cooler being a problem is if it's too big, or its too cold outside.
Overcooling the oil can be just as bad as under, but with our stock oil coolers it shouldnt be an issue.
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 10-29-2010, 04:30 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Paul, ask your engine builder what the target oil temperature should be and specifcally why "he doesn't believe in oil coolers". Your dyno scenario doesn't really mean much. Running the car on the dyno is nothing like the race track.
Panoz thought it necessary to run an oil cooler on the school cars. The issues I've seen with guys locally are likely due to heat-related problems. I doubt running your oil hotter is a solution for increased reliability.
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
Old 10-30-2010, 01:12 PM
Panozdoc ... Do you have a cooler for sale ; new ; what size , price ... If so , call me 218.393.4848 / thanks Paul W.
Old 11-08-2010, 02:26 AM
NZGTRA17 NZGTRA17 is offline
Paul, I hope that you have gone ahead and fitted a cooler. I normally race in low ambient temps of around 15 - 20 Celcius and I still see oil temps of up to 115 degs Celcius.
I am currently on an extended holiday in Malaysia. Ambient temps here are often in the 30 - 38 degs Celcius range. It seems that it is common for some makes of car here to run big end bearings when they are run for prolonged periods on the motorway at high speed (160+kph). This seems to only affect cars that do not have an oil cooler fitted and the common fix recommended by manufacturers is to fit a cooler or slow down.
I have never run a cooler for sprint races (10 laps or less), but certainly would not run endurance events without one.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Oil drip...oil cooler lines? gonzoblazer Problem Diagnosis 5 01-27-2010 03:27 PM
Help Oil Cooler Lines oscales Tahoe 4 09-09-2009 08:44 PM
oil cooler or not? taffyboy 3 Series 0 07-05-2007 12:25 PM
engine oil cooler kit big blue h22 Prelude 8 01-08-2002 05:42 AM
Auto Trans oil cooler hobie16 Maintenance 2 12-01-2001 10:16 PM
