Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 10-19-2010, 10:34 PM
flynvy5 flynvy5 is offline
check engine light on
Guys and Gals
I'm new to the forum. I just purchased a 98 chevy venture and the check engine light is on. I'm not able to read the codes with my code reader. I have checked the pinout on the obd2 connector and get no voltage from pin 16. Any suggestions?
Old 10-20-2010, 10:03 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: check engine light on
Check all fuses.
MT
Old 10-20-2010, 10:14 AM
I have removed the DRL fuse due to the daytime sensor going bad. Nowthe lights are on the switch as i feel they should be. Any fuse i should be looking at first. As i said i have no power going to the 12V lead on the obd2
Thanks
Old 10-20-2010, 10:39 AM
Scrapper Scrapper is offline
AF Premium User
try to reset your computer take neg cable off for about 10 or 15 mins. and then hook back up see if it goes out? if not take it to autozone or advanced have it plugged in. probably in coilpack or 0-2 sensor or maybe something else?
Old 10-20-2010, 11:15 AM
MT-2500's Avatar
AF - Advisor
Thanks
As in all means all.
And make sure 12 volts to both sides key on.
MT
Old 10-20-2010, 11:21 AM
MT-2500's Avatar
AF - Advisor
Could be the fuse you removed !!!!
CIGAR/DLC 15 amp should power pin 16 amp cigar lighter.
MT
Old 10-20-2010, 01:38 PM
i have replaced the drl fuse and still no power to the 12V lead on the OBD connector
Old 10-20-2010, 03:30 PM
MT-2500's Avatar
AF - Advisor
Check all fuses!!!!
As in no power to pin 16.
Did you check all other fuses for 12 volt power to both sides of them.
Did you check the cigar lighter fuse?
Does cigar lighter work?
Or have power to it?
MT
Old 10-20-2010, 03:38 PM
MT-2500's Avatar
AF - Advisor
Go straight up 6 fuses from the DRL fuse and find and check the cigar lighter fuse for 12 volts to both sides of it key on.
MT
Old 10-20-2010, 07:18 PM
yes i have power on all the fuses both sides just not getting anything at the obd connector. Where is the ecu located so i can tell if the obd port is connected.
Old 10-21-2010, 01:07 PM
MT-2500's Avatar
AF - Advisor
You did not tell us if your cigar lighter works or has power to it.
Power to pin 16 OBD11 connector comes from cigar lighter fuse.
If power on that fuse and no power to pin 16 you have a broken wire in between.
If that is the problem.
I would suggest you run a new wire from cigar lighter fuse to pin 16.
MT
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 11:44 AM
ets off light and check engine light on drpjay62 Cavalier Problem Diagnosis 1 11-26-2009 03:27 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 03:53 PM
1998 Malibu - check engine light jpar1983 Malibu 2 10-28-2009 08:49 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 06:16 PM
