Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-19-2010, 04:36 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Slight cold start issue
When i first go to start my car the RPMs "chug" around 500rpm when i initially start it but then seem to jump back up to where they should. Once the engine is warm it will start like it should every time. I don't think its a choke issue but who knows. Its not a huge deal but just another bug i'd like to fix.
Of course i made a quick video on this one just to make the diagnosis easier
http://www.youtube.com/watch?v=QW598kmMQ0w
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 10-19-2010, 04:56 PM
danielsatur danielsatur is offline
Re: Slight cold start issue
Just like the symptoms of a bad Massive Air flow sensor,a cold hard start.
But no MAF, check your throttle plate, or choke plate.
Old 10-19-2010, 07:13 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Welcome to the wonderful world of carburetors. Mine does the same thing, don't worry about it.
Mass airflow sensors need not apply. :/
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-20-2010, 12:03 PM
Check the automatic choke, and fuel pressure.
Old 10-20-2010, 01:08 PM
bhw33191's Avatar
You say check the fuel pressure..could running 2 fuel filters be a problem and cause too much resistence? I'm running an inline fuel filter in addition to the one built into the Qjet.
Old 10-20-2010, 02:15 PM
Older Auomobiles had a heat sheild, the hot air rise tube going from the exhaust manifold to the carb would adjust the electric thermomatic choke.
You could probably go with electric cooling fans, and a thermo sensor, so the engine will heat up quicker.
Old 10-20-2010, 05:30 PM
j cAT j cAT is offline
the cold start idle should be 1700rpm. Tap the throttle pedal once should drop to about 1200 rpm ,,, if the engine starts but idles too low this is usually the choke not fully closing on a cold start .
when cold, key off ,,,,check the choke for operation. the choke idle cam does rust and sticks easy. the adjustments should not be messed with if it worked before.
when adjusting the choke plate use a drill bit for about .157 inches to .170 inches .. most likely the electric choke stove is getting weak .
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
Cold starting issues. E Honda Corvette 1 11-07-2005 09:52 PM
96 stratus 2.4l fuel injected cold start issue paedbo Stratus 1 11-19-2004 09:56 PM
1995 Cierra cold start issue cierradude Cutlass Series 3 08-23-2004 02:15 AM
Zetec Cold-Starting Issues kcarlen Focus | C Max 8 05-13-2004 08:50 PM
