Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-21-2004, 09:14 PM
cierradude cierradude is offline
1995 Cierra cold start issue
My '95 Cierra with a 3.1 engine starts right up every morning,
but after it runs for a mimute or two, it starts sputtering.
It does this either just in park or if i start to drive.
Than it stops after maybe 5-10 seconds after it starts.
It has a new fuel filter. Any ideas?
Thanks!
Old 08-22-2004, 12:31 AM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: 1995 Cierra cold start issue
Sounds like you need to clean out your Idle Air Control(IAC) motor. Carbon builds up in there, second the area in the intake under the EGR valve also develops carbon deposits that need to be cleaned out. Last, you need to make sure your throttle body is also cleaned out. Use Gumout and some green Scotchbrite pad that is used for cleaning dishes. It would gouge the throttle body. You can also use an old toothbrush. -Chris
Old 08-22-2004, 06:04 AM
Wink
Thanks Chris, I will check those!
Old 08-23-2004, 02:15 AM
sorry....i meant that the scotchbrite will NOT damage the throttle body, sorry for the typo.
