Old 10-18-2010, 11:01 PM
monte445 monte445 is offline
98 taurus no start.
was driving it on day and it just died. has new battery, it has no lights, no dash lights, no options work I.E, radio, pw, pl, ps, sun roof, etc. i checked the battey full charge, ignition switch good, ecu good, power going to the fuse blocks, main fuse good. any one have any ideas
Old 10-19-2010, 06:46 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 98 taurus no start.
Were you using a multimeter or test light to check for voltage to the fuse block? If using a multimeter, the input impedance is so high that you could have a loose or corroded connection between the battery terminal and where you were measuring and still read what appears to be a good voltage. However, the current would be limited to the extent where it would not be able to power anything. Did you try the same measurement, then turn the headlights on and see if the voltage changes? If so, I'd suspect an issue with the connections. If not, then you probably have a fuse or fusible link that is open somewhere.
-Rod
Old 10-20-2010, 10:17 PM
thanks for the help. i found it.
you know any thing about the abs system. when you brake you can feel and here the abs modual / motor, buzz. no light yet. All the wheel sensors work according to my task master, i bleed the brake system and the abs system twice. not dont have the bleed option on my scan tool. i did notice that the brake switch doesnt say on when brakes pressest, but tails do light up.
Old 10-20-2010, 10:27 PM
shorod's Avatar
SHO No Mo
Care to share what you found to be the electrical issue?
As for the ABS issue, does your scan tool allow you to monitor the individual wheel speed sensors? You might have a sensor that is reporting 0 mph sooner than the others, or showing an irregular speed due to a cracked or dirty tone ring. Depending on the severity, the module may not be picking it up as an issue and toggling a code.
-Rod
Old 10-20-2010, 11:12 PM
it monitors them all, they where all one mph from each other. but i noticed when sitting still it reads 2mph. i 97 tied it on my taurus and it reads 0mph when sitting still.
Old 10-20-2010, 11:47 PM
im sure i just found the prob.. the previous owner has 60 in the front and 65s in the rear
Old 10-21-2010, 06:36 AM
shorod's Avatar
SHO No Mo
Are you referring to the tire's aspect ratio? If so, what is the tire width? If the width is also different the tire height could be close enough to not be the cause of the ABS.
From post #5 am I to understand that you also have a 1997 Taurus and, when monitoring that car, at a stop your tool reads 0 mph on all four wheels, but on your '98 all four wheels show 2 mph when stopped?
-Rod
Old 10-25-2010, 01:04 PM
yea thats correct
The 98 has 205 60 15 in the front and 205 65 15 in the rear. I tested the brake light switch and it has ohms and the harnes has 12v coming out of it.
Is there another switch on the peddal that tells the computer when the brakes are pressed. the reason im asking is when my scan tools hooked up to it and i press the brake it still doesnt reconise the peddal is pressed.
sorry for the late reply its been a crazy last few days
Old 10-25-2010, 03:31 PM
i forgot to mention that i double checked the wheel speed sensors all read 2 at a stop
Old 10-25-2010, 04:08 PM
inafogg inafogg is offline
when this noise happens does it sound like abs is working??
you drive car & when ever brakes are applied you hear the clicking noise??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 10-25-2010, 09:30 PM
shorod's Avatar
SHO No Mo
The brake pedal position switch for the ABS has a light green/red wire (feed) and a red/light green wire (to ABS control module). This switch closes when the brake pedal is pressed. This is the same brake pedal position switch that is used for the brake lights and cruise control. There is another switch at the brake pedal that is a redundant switch to disengage the cruise control upon further pressing of the brake pedal if the first switch fails. This switch is fed from the same supply (red/light green) but goes to the cruise control servo as a tan/orange wire.
-Rod
Old 10-26-2010, 12:44 AM
do you think the cruise control switch could be my issue
Old 10-26-2010, 07:02 AM
shorod's Avatar
SHO No Mo
No, the brake pedal switch for the cruise is out of circuit for the ABS system. I don't think the brake pedal position switch for the brake lights and ABS would be the cause of the issue you describe either.
You have enough inconsistencies in what the Task Master is telling you that I'm not sure I'd put a lot of faith in it, even though it seems to work fine on the '97.
-Rod
2003 Alero will not start, only service engine light comes on with key turned to ACC DelbertJay Alero 2 02-20-2012 04:05 PM
2002 Taurus No Start fugiman852001 Taurus | Taurus Wagon 1 09-11-2009 06:20 AM
98' Taurus starting problem StorminMarv Taurus | Taurus Wagon 2 03-03-2004 07:16 PM
1997 taurus starting problem cmerc Taurus | Taurus Wagon 1 02-15-2004 07:56 PM
Ford Taurus Started mstngcobrasvt98 Car Modeling 9 01-03-2003 11:12 AM
