Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-18-2010, 03:19 PM
dtownfb dtownfb is offline
2006 Camry - new brake pads, grinding noise
I have a 2006 Camry LE. About a month ago I had the front brake pads replaced and rotors cut (68,000 miles). I'm the third owner but have the service records. I purchased the Camry at 41,000 miles. the rotors were cut at 35,000 miles because the owner complained of shuddering when braking. About a 2 days after replacing the pads, my brakes starting grinding when stopping and got progressively worst. My mechanic re-surfaced the rotors. This worked for one day and the grinding has started again. I believe he used Napa Ultra Premium brake pads.
is this a simple matter that the rotors need to be replaced or could there be another problem?
Old 10-18-2010, 05:17 PM
inafogg inafogg is offline
Re: 2006 Camry - new brake pads, grinding noise
could be a simple problem.rotors are to thin or heat spots on rotor
either way if it is rotors they will need replacing
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 10-18-2010, 05:45 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
^ In addition to what Inafogg stated, it can also be the composition of the pads themselves or the lack of using the proper Toyota or aftermarket shims to eliminate the noise. Since you paid to have the work done, advise your mechanic that the problem is still there. It should be up to him or her to resolve the issue.
Mike
Old 10-19-2010, 09:15 PM
I'll ask him about the shims and replacing ther rotors. Originally I had told him to replace the rotors if necessary. So i was prepared to pay fo rthem anyway. I'll offer to pay for the rotors and he can cover the labor.
thanks
Old 10-21-2010, 01:09 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
1) Make sure the pads/backing shims are seated properly against the piston bore...remove any rust.
2) Make sure the caliper pistons have free movement inside the cups. They should be retractable with ease using a c-clamp or other spreader tool.
3) make sure the calipers slide freely on the mounting slide pins.
Any one of these can result in misalignment of the pads against the rotors causing uneven pressure across the pad/rotor interface.
Semi-metallic pads are also harsher on rotors, so beware of their use.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-02-2010, 01:22 PM
Follow-up: My mechanic decided to replace both the pads and rotors with Toyota parts. Based on what everyone has been posting, I guess the pads were too rough on the rotors and causing the grinding. New pads and rotors solved the problem.
New Brake Pads Grinding Rotors HELP williamjay199 Taurus | Taurus Wagon 1 07-13-2009 12:51 PM
Rear brakes (drums) grinding noise hayesbcajh Caravan | Voyager 5 03-23-2009 09:45 AM
97 Venture 142kmi w/brake pad scrapping noise cjstew4 Venture 5 11-29-2006 05:00 PM
Camry OEM Brake Pads & Shoes Techventure Camry/Camry Hybrid/Vista 6 02-09-2006 10:21 PM
God Awful grinding on new brake pads scaradine Malibu 4 09-29-2005 06:46 PM
